Vortex generators will be 3D printed on a panel, which is then to be slotted onto a foam aerofoil to be tested in the wind tunnel for performance and flow physics.
What I want to know is which aspect ratio to use?
Rectangular wing, need a chord length and span.
Max wing span is 700mm.
closed as unclear what you're asking by J. Hougaard, SMS von der Tann, fooot, mins, kevin Nov 2 '16 at 9:11
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
What is it you want to test?
Do you want to test the 2D characteristics of an airfoil? Then make it the width of the windtunnel. The wind tunnel walls act like mirrors, so you will have the behaviour of an infinite wing.
If you want to test a 3D wing on a model, you need to use coherent scale. Use the same scale for the fuselage/wing/empennage.
