10
A Russian aircraft carrier Admiral Kuznetsov has an interesting aspect: the edge of the runway is raised, which “pushes” the plane in the air during the takeoff. Looking at takeoff videos, the curved edge seems very natural.
Admiral Kuznetsov
All USA aircraft carriers I can think of have an absolutely flat deck, similarly to, for instance, USS Abraham Lincoln:
USS Abraham Lincoln
The Admiral Kuznetsov's curved deck provides benefits, so why were most carriers not built the same way?
  • 8
    $\begingroup$ Guys, please read the whole question before closing as a duplicate... the first part of the question, the benefits of the curved deck, is answered in the "duplicate" question, but the second piece of the question, why aren't most carriers built this way, is NOT answered in the "duplicate" question. There is a valid question here which is NOT answered yet. Voting to re-open. $\endgroup$ – Ralph J Oct 31 '16 at 21:52
    $\begingroup$ It's definitely an effect of thermal expansion, they used different material layers for the deck and they are above an underwater geyser. The effect will disappear with next shower. Complete demonstration on this scale model. $\endgroup$ – mins Nov 1 '16 at 14:58
  • $\begingroup$ Are you serious? No this is a structural design meant to serve as a ramp, not thermal expansion lmao $\endgroup$ – Jihyun Apr 9 '19 at 15:49
  • $\begingroup$ To mention another disadvantage: if take-off doesn't quite work, you end up getting run over by the ship, which can make for a bad day. $\endgroup$ – Roger Apr 9 '19 at 15:54
  • $\begingroup$ "What is the benefit of a curved up flight deck?" -- Up is always the best way to curve the flight deck. Sideways or down don't work so well. $\endgroup$ – quiet flyer Nov 2 '20 at 19:14
13
Because the method of launching aircraft are completely different in these carriers. Carriers with ski-jump, initially designed for RN Harriers (as @Simon already has explained), requires that the aircraft take-off under its own power.
On the other hand, large aircraft carriers having flat decks have their aircraft launched by catapults (with a notable exception) which basically throw the aircraft from the deck. Though this system is heavy, expensive and complicated, it brings significant advantages to the table:
  • It allows aircraft with higher t/o weight to operate from the carriers. USN operates F/A-18E/F Super Hornets, which weigh ~30 tons from its carriers (they even operated the heavier F-14 Tomcats). The ski jumps, on the other hand restrict the aircraft t/o weight (which means less ordnance), as the Chinese are finding out. Indian Navy operates Mig-29Ks from its carrier, but they are lighter (~25t).
  • The catapult launch offers more options - it can operate in wider range of sea conditions compared to the ski-jump and can even launch aircraft even if one of the engines fail during the launch, a feat usually not possible for the aircraft in ski-jump.
  • The catapult allows for a significantly higher takeoff rate, which means a higher sortie generation. As rusnavy.com notes:
With its four catapults, a US carrier is capable to shoot one aircraft in every 15 seconds. Kuznetsov has only three takeoff tracks. Moreover, two bow tracks are not intended for fully-loaded aircrafts! They can take off Kuznetsov only from one track which starts far behind the midship, i.e. an aircraft must run almost the whole flight deck! Comparing to catapult, takeoff rate of ski-ramp is at least twice lower.
  • The catapult allows the launching of support aircraft (like AWACS), which have low thrust-weight ratio and would not be able to take off under their own power.
  • The ski jump takes up space in two ways- physically, it occupies front deck space (on the other hand, aircraft can be parked over catapults when not in use), while the take off run required by the aircraft (greater with more gross weight) eats up more space, leading to limitations of the number of aircraft on the deck.
As for the exception, the USN operates carriers without ski-jumps, but these are not called as such- they are called amphibious warfare ships an operate only VTOL aircraft like the F-35 Lightening II and V-22 Osprey.
    $\begingroup$ It's not that much the t/o weight but rather the thrust-to-weight ratio that plays the role here. (It's just that, very generally, larger aircraft have such ratio lower). Kuznetsov can operate Su-33, which is heavier than F/A-18F. But it couldn't, say, a lighter EA-6B. $\endgroup$ – Zeus Nov 2 '16 at 9:08
    $\begingroup$ This answer seems to mainly list the benefits of having a flat deck, but the question was about the benefits of having a curved deck $\endgroup$ – expeditedescent Aug 27 '17 at 11:59
  • $\begingroup$ Actually, the AWACS can take off under its own power using the landing area as a runway. $\endgroup$ – MikeY Apr 9 '19 at 3:09
  • $\begingroup$ @J.Hougaard The question asks "Why were most carriers not built [with ski-jumps]?", so this answer seems entirely on-point to me. $\endgroup$ – David Richerby Apr 9 '19 at 14:22
10
The ramp design may be referred to as STOBAR (Short Take-Off But Arrested Recovery), and this is a fairly simple design to implement. However, the complexity is pushed into the aircraft. Since there is no catapult assistance, aircraft have a hard requirement to take off in the space available, given the ramp at the end. This limits the types of aircraft that can be launched, typically to fighter aircraft that already have high thrust to weight ratios, or aircraft specifically designed for short takeoff capability. Takeoff weight may be limited. Aircraft still must be equipped with an arresting hook for landing.
A catapult system may be referred to as CATOBAR (Catapult Assisted Take-Off But Arrested Recovery), and this allows for launching a much wider range of aircraft. For example, CATOBAR carriers can launch large aircraft like the C-2 or E-2. These aircraft would not be able to take off from a carrier without catapult assistance, and provide carrier resupply or AWACS capability. Even fighters that may be able to take off without assistance can be launched with much more payload. However, this capability comes with a cost. The aircraft will need to have strengthened landing gear to withstand catapult launches. The carrier is also made more complex, placing an additional demand on a boiler or generator to provide the large amount of steam or electricity needed to launch aircraft. Modern US carriers are nuclear powered, providing the energy needed for this system.
There are also practical considerations in aircraft carrier design. The ramped deck may detract from available space on deck for parking aircraft. You can find many pictures of CATOBAR carriers with aircraft parked on the bow area, which would be difficult on a STOBAR carrier. The angled deck on modern carriers would still allow for launch and recovery of aircraft on a CATOBAR carrier with the bow area occupied. The ramp also reduces forward visibility for maneuvering the carrier. On a CATOBAR carrier, the flight deck must be designed to include the catapults, while on a STOBAR carrier, only the blast deflectors must be integrated into the deck.
Think of the ramp as free lift with no maximum lift coefficient so you can't stall while using it, and zero induced drag.
If you could make a catapult that curved upward...
