The EUROCONTROL Concept of the Flexible Use of Airspace (FUA) is that:
  1. an ASM concept currently applied in the ECAC area and based on the fundamental principle that airspace should no longer be designated as either pure civil or military airspace, but rather be considered as one continuum in which all airspace user requirements have to be accommodated
  2. an airspace management concept applied in the European Civil Aviation Conference area on the basis of the “Airspace management handbook for the application of the concept of the flexible use of airspace” issued by Eurocontrol
EUROCONTROL also defines Special Use Airspace (SUA) as:
Airspace of defined dimensions identified by an area on the surface of the earth wherein activities must be confined because of their nature and/or wherein limitations may be imposed upon aircraft operations that are not a part of those activities.
Question: what is the relationship exists between SUA and FUA? Can they be considered as the same thing? Is SUA a special type of FUA or vice-versa? What is the difference essentially?
  • $\begingroup$ You can think of it as flexible use of special use airspaces. $\endgroup$ Oct 27, 2016 at 16:58
Flexible Use of Airspace is a concept rather than a part of airspace (which SUA is), where the whole airspace is used for both restricted and unrestricted (civil) activities. According to FAA:
• The FAA version of Flexible Use of Airspace (FUA) is called “Joint Use Airspace”
• Although not defined as such, the domestic United States could be labeled as being completely FUA airspace.
The Special Use Airspace (SUA) is a portion of the Flexible Use Airspace (FUA), in which unrelated activities have been restricted:
In accordance with the FUA concept, Special Use Airspace is a defined portion of airspace which may be temporarily reserved for specific activities which require the restriction or segregation of other traffic.
Basically, in a FUA, SUA will be a temporary restriction (rather than a permanent one). Eurocontrol also says the same thing:
Airspace is no longer designated as purely "civil" or "military" airspace, but considered as one continuum and allocated according to user requirements.
Any necessary airspace segregation is temporary, based on real-time usage within a specific time period.
Related concept is Advanced Flexible Use of Airspace in which SUA is allotted in real time.
An airspace management concept in which airspace is managed as a single entity and in which there are no fixed structures and airspace reservations for special airspace activity are allocated in real time.
