I pretty much understand the way a wing works and the different ways of explaining it, what I don´t understand is why the lift on a subsonic wing manifest itself at the 25% chord....
The 50% chord would seem more logical if You ask me....
If I was told that the lift IS NOT at the 50% chord and were told to make an (uneducated...;- ) guess as to where it then would be, I would probably guess at the 75% chord rather than the 25%....
As a plane like the Dash 7 which has VERY efficient flaps has its nose pressed down if the flaps are deployed at too high a speed, or, as a wing-shaped leaf would turn nose down at first....
I understand that the lift manifests itself at the 25% chord, I just haven't got a clue as to WHY....???
I just asked a kind of similar question about the lift-shift that occurs at supersonic speeds. I was thinking of asking this question together with that, but I guess it's more of a question of its own....
