How long and how wide should the runway be to take off or land a Gulfstream 650 on private ranch property?
    $\begingroup$ It should be noted that you will need some clear space on both ends of the runway as well, your over all land needs will be notably longer than your book runway distance. $\endgroup$
    – Dave
    Oct 18, 2016 at 3:33
  • 8
    $\begingroup$ At what altitude? $\endgroup$ Oct 18, 2016 at 5:03
    $\begingroup$ Depends on altitude, air temperature, weight, winds, and obstructions $\endgroup$
    – Steve Kuo
    Oct 21, 2016 at 18:09
75-foot wide runway, and since you'll need to takeoff after landing, the takeoff distance at maximum takeoff weight at sea level is 5,858 feet.
Sources:
    $\begingroup$ Accelerate-stop and accelerate-go distance might be helpful too. $\endgroup$
    – J W
    Oct 18, 2016 at 15:27
This one is based upon aircraft loadout, field elevation, surface winds and ambient atmospherics. You will have to consult the airplane flight manual and performance tables specifically approved by Gulfstream for use in the particular G650 in question for required runway length. Typical takeoff lengths are therefore going to vary between about 3000 - 8000 feet depending on the variables listed above with a quoted metric at 5858 feet at MSL, calm winds at STP and MTOW.
Often times, the distance to clear a 50 ft obstacle at a particular airfield is more useful to the flight crew than the mere runway length needed to take off; these figures are also published in the performance tables for the jet.
As to runway width, I'm not aware of a specific number for this; at a guess at least 3x the wheel track of the main gear and at least, say, 100ft of clearance for obstacles from centerline. That's still a pretty tight squeeze and unrealistic for normal operations. Given the kinds of airports this jet will likely be operating from, this really isn't concern.
Unless you want your Gulf Stream to look something like this, I would be more concerned about the strength of the runway surface in relation to the ACN of the G650 (which does not appear to be published). BTW, this is a G450 in the picture.
Gulf stream sunken into surface
