Is it legal to build and fly a scale 1m:20cm Boeing C-17 for use in flying from the U.K. to other countries to deliver aid in places that are hard to reach?
For example, on top of a large hill where it is hard to get aid workers on foot up there, or too expensive to air drop supplies to people on top of the hill.
Is it legal to build and fly a scale 1m:20cm Boeing C-17 for use in flying from the U.K. [...]
Building an aircraft is likely not regulated (intellectual property laws still apply), it's probably like building a car in your garage, however using an aircraft, specially outside your own property is regulated. Drone use, in UK, is regulated by CAA as for any aircraft, the main reference is:
Article 23 (Exceptions from application of provisions of the Order for certain classes of aircraft) specifies that some aircraft are excluded from the scope of the order, this includes:
  • any small unmanned aircraft.
So some drones can be used quite freely. Indeed you are always responsible of what happens with your drone. Some articles still apply and in particular art. 94:
  • Art. 94 - Small unmanned aircraft: Need to fly safely, and can't drop anything that can endanger persons or property. Must maintain direct, unaided visual contact with the aircraft. Unless authorized by ATC, weight is limited to 7 kg when inside A, C, D or E airspace, when close to an airfield, or when flying higher than 400 ft.
This article alone prevents free use in your case.
Source
For the sake of reference, let's look at the other articles:
  • Art. 91 - Dropping articles for purposes of agriculture etc. and grant of aerial application certificate: This is not allowed without authorization.
  • Art. 92 - Mooring, tethering, towing, use of cables, etc.: Use of cables being a hazard for other aircraft, some cases are prohibited, e.g. using cables in a controlled airspace, or near an airfield.
  • Art. 95 - Small unmanned surveillance aircraft: Not applicable.
  • Art. 241: Endangering safety of any person or property: Don't, even recklessly or negligently!
  • Art. 239 and 257: Power to prohibit or restrict flying: You may be prohibited to fly if circumstances call for; Art. 265: Offences and penalties: How you'll be fined if you do something not allowed.
For uses not covered by art. 23, CAA says:
If you want to use a small unmanned aircraft or drone outside of the operating limits set out in the Air Navigation Order then you will need Permission from the CAA, even if your activity is non-commercial. Applications for this type of Permission are considered on a case by case basis.
  • Permissions are granted on a case by case basis, they may be valid for one flight or for a period of up to 12 months.
  • An operating manual must be prepared and submitted to the CAA, and a designed pilot must be assessed by CAA as having the competences required to fly the missions.
In addition, as mass increases, regulation becomes more stringent:
Unlike small drones, unmanned aircraft with an operating mass of more than 20 kg are subject to the whole of the UK Aviation regulations (as listed within the UK Air Navigation Order – ANO), although they may be exempted from certain requirements by the CAA.
Unmanned aircraft with a mass of more than 150 kg are also subject to additional certification requirements as determined by the European Aviation Safety Agency - EASA.
In the UK, "large" drones
are not currently permitted to fly in any non-segregated airspace [...] without specific permission from the CAA.
Flying from the U.K. to other countries [...]
UK is not part of the Schengen Area, flying to a Schengen Area country will be considered as if flying to a foreign country.
Flying to (or over) any other country requires to follow local laws, which vary, but likely include:
  • Getting an authorization to fly a drone from the local agency equivalent to CAA. Regulations may be more limiting than in UK.
  • Getting a specific authorization if the pilot is a foreigner. In some countries this may be not allowed at all.
  • Getting an authorization to use a camera. Some countries don't welcome flying cameras, some just exclude their use at specific locations.
ICAO Appendix 4 to Annex 2 of the Chicago Convention (Remotely Piloted Aircraft Systems) lists the few agreed principles between ICAO members, including:
  • An RPA shall not be operated across the territory of another State, without special authorization issued by each State in which the flight is to operate [...]
  • An RPA shall not be operated over the high seas without prior coordination with the appropriate ATS authority.
To deliver aid in places that are hard to reach, for example, on top of a large hill where it is hard to get aid workers on foot up there [...]
UPS-backed Rwandan blood deliveries (source)
Why not launching your drone close to the destination, instead of flying from the UK, think about aspects like:
  • The ability to maintain a radio link with a significant data rate for the camera. This can be difficult without using a satellite.
  • A drone limited range, even if fuel is used in place of batteries.
More on unmanned aircraft in UK airspace:
    $\begingroup$ and emergency situations would almost certainly fall in the category of "prohibited to fly if circumstances require" almost automatically as flying would potentially endanger heli ambulances and other official emergency response vehicles. $\endgroup$
    – jwenting
    Oct 16, 2016 at 5:33
  • $\begingroup$ @jwenting: This aspect could be coordinated, but that would be possible for a local emergency NGO, known by and trained with State emergency services. $\endgroup$
    – mins
    Oct 16, 2016 at 12:27
It depends on the regulations of the (target) country. In general, UK CAA requires permissions for operating non-commercial drones for operating in its territory. These can be either ad hoc or permanent approval:
and
An individual or organisation that would like to conduct regular flights with their drone, however, will probably need to submit an operating manual to the CAA for a permanent approval. This will allow greater freedom to operate continuously without the need to seek ad hoc approvals.
This type of Permission could be of use to:
  • emergency services, ...
In fact, (small) drones are being used in life-saving delivery of medical supplies already, for example, in Uganda. In that case you will have to be cleared by that nation's aviation regulatory body. In any case, I'm not aware of a lot of countries that can be served by a 1:5 scale drone from UK.
