I imagine a fixed wing airplane design that's a lot more symmetric than what I see today. This symmetric design has wings in the middle of the fuselage (neither high wing nor low wing), and the empennage is a symmetric cross. Two vertical fins, one on top and one on bottom, and two horizontal stabilizers. The tail fuselage would taper symmetrically too, instead of the underslope with flat top we usually see today. This would make the fuselage closer to a Sears–Haack body, which I believe is ideal.
In other words, it would look a lot like the XB-42 Mixmaster:
XB-42 Mixmaster
Ignore the weird engine. AFAIK, this design could use an engine anywhere. BTW, this is the only aircraft I know with the middle-wing and symmetric cross tail design—whether experimental or production aircraft.)
The reason I imagine this is so the control surfaces are much more aligned with the center of mass. So the rudders, elevators, and ailerons will not produce any adverse torques when used. I think this will be more efficient, especially when using trims, and also is a simpler design as far as I can tell.
To get around the problem of tail strikes, I imagine a single tail wheel attached underneath it. For small aircraft it might not need to retract. For larger aircraft, I don't know how or where it would retract to, but maybe instead some kind of aerodynamic shield can enclose/open around it, like a prolate or oblate spheroid shape.
(An alternate symmetric design would be an X-shaped empennage—same shape, just rotated 45 degrees. I think for a given yaw, the combination of control surfaces would produce more drag though, but it's a way to increase ground clearance.)
(A more exotic alternate might be to forget about takeoff rotation entirely, and just increase takeoff speed and the length required to literally lift off without pitching up the nose. This might not be feasible for large commercial aircraft though.)
(But maybe best is to add canards with their own elevators, or all-moving canards, which will push up the nose and pivot at the wheel.)
To me this symmetric design seems simpler and versatile. By versatile I mean it looks like it could be used for small and large aircraft, whether prop-engine or jet engine, military or civilian, and not really mattering where the engines are located either.
Is there anything wrong with this design? Why is it not used more often? In fact I do not know of a single production aircraft with this design.
If anyone knows of any aircraft in this configuration, whether experimental or production, please provide a link so I can read more about it and maybe discover some reasons for its success or failure.
    $\begingroup$ This is how a missile is designed. $\endgroup$
    – kevin
    Oct 9, 2016 at 6:04
4 Answers 4
You are right, a symmetric layout would reduce flight mechanical complications like rudder movements causing a rolling moment on top of the intended yawing moment. But would it be worth it? Airplanes usually fly straight courses and keep manoeuvring down to a minimum. The autopilot will deal with the cross couplings just fine, and aerodynamically the added control surface deflections are negligible.
But the new complications coming with the ventral fin are harder to ignore. As you said, rotation at take-off will be limited and you need to take off B-52 style. Note that the B-52 needs a high wing already to prevent its wingtips from scraping on the runway when there is too little lift to bend them up (beefing up the outrigger wheels would also be an option, but adds weight). Now the aircraft will climb with a nose-down attitude which increases drag slightly. Only the protection for the tail-mounted propeller afforded by the ventral tail justified its existence in the XB-42 (look at the Do-335 for another example). When the XB-42 became the jet-powered XB-43, the ventral fin was removed.
Or how should you load and unload large cargo if not with a rear ramp? The ventral tail would make access to this ramp impossible. Loading from the front needs a stronger and heavier nose wheel or additional struts like on the An-124. Woe betide the crew who forgets to lower the strut before unloading the main battle tank through the front doors. This complication never arises with a rear ramp.
Now for the fuselage shape: The symmetric tube is not as bad as the current upswept tail, but not ideal. Look at gliders: Here the fuselage follows the upwash ahead and the downwash aft of the wing to create the least drag. But again this will restrict the possible rotation angle at take-off. Especially with wing sweep you are better off with an upswept rear fuselage and a shorter runway. Just think of all the resistance in the population if you need to double the runway length at all major airports. Or do you want to limit the utility of your new design by restricting it to Edwards AFB?
Symmetry is only worth it if the aircraft is designed for aerobatics. Even then, a symmetric wing airfoil is much more important than a symmetric vertical stabilizer.
  • $\begingroup$ Do-335 has symmetric empannage, but the wing is low, not middle. And yeah, I was imagining a forward ramp for loading cargo. I think a solution to takeoff rotation is to add canards with their own elevators, to push the nose up and pivot at the tail wheel. The symmetric tube is not as bad as the current upswept tail, but not ideal. How are you measuring "ideal" here? I was under the impression that the fuselage with the least drag is a sears-hack body. Are you thinking of some lifting body design, like a tadpole-shape or camber to the body? I'll make some edits. $\endgroup$
    – DrZ214
    Oct 9, 2016 at 6:10
  • $\begingroup$ I know where the wing on the Do-335 was, thank you. I was referring to the tail. The Sears-Haack body is the optimum lengthwise thickness distribution in supersonic flow; here I thought of a fuselage with the least local inclination and, consequently, the least crossflow and separation. That would indeed be ideal. Yes, it would have camber. Rotating around the tail wheel only works when the cg is close to the tail wheel, too. $\endgroup$ Oct 9, 2016 at 11:38
  • $\begingroup$ What is "local inclination" and "least crossflow"? And are you sure about that last remark? Old-school WW2 planes had two main gear under the wings and one tail wheel, and had engines right in the nose, so i imagine the cg is nowhere near the tail wheel yet they apparently could takeoff without much trouble. $\endgroup$
    – DrZ214
    Oct 9, 2016 at 23:40
  • $\begingroup$ @DrZ214: Local inclination means angle of the surface versus the local direction of flow were the body not there. Crossflow is the result of too much inclination: Flow going across and not along the body. And I am very sure about the last sentence. A taildragger does not rotate around the tailwheel. Rotation is always around the main wheels. $\endgroup$ Oct 10, 2016 at 6:44
    $\begingroup$ @DrZ214, note that the tail-draggers sit on the ground with nose very high, higher than the take-off attitude. That way they lift the tail first during take-off roll and then lower it back a bit, but not all the way to the ground, to rotate. Some unusual examples sit at exactly the take-off attitude and lift off from all three wheels at once. But the main wheels never lift off first. $\endgroup$
    Oct 10, 2016 at 21:37
The biggest single problem with this is the location of the main spar - across the middle of the fuselage. This might not be a problem for single seat military or sports aircraft but would be a major headache for almost any other design. Imagine trying to load 100+ passengers with 50% of them having to clamber over or under a major obstruction in the cabin.
Yes, you can engineer around this but the resultant solution is likely to be heavier and more complex than simply moving the wing up or down and out of the way.
    $\begingroup$ I didn't think of main spar problems. Isn't it possible to have "cantilever wings" that attach to a main rib, but don't penetrate through the cabin? I may open a new question about that. $\endgroup$
    – DrZ214
    Oct 9, 2016 at 5:54
    $\begingroup$ @DrZ214: Airsick is right, you need to carry the bending moment from one wing to the other, unless you want a folding wing design even before take-off. In jets like the F-104 (mid-wing!) the spar ended in several beefy fuselage frames so the intake and engine could be placed where the spar usually would be. $\endgroup$ Oct 9, 2016 at 11:43
  • $\begingroup$ You could also add the additional headache of the tail scraping at rotation during takeoff $\endgroup$
    – Notts90
    Oct 9, 2016 at 12:28
  • $\begingroup$ Couldn't you lower the main wing just a bit, into the cabin floor? FWIW, for instance B777 has the floor almost in the middle of the cross-section... $\endgroup$
    – yo'
    Oct 10, 2016 at 13:19
  • $\begingroup$ You can do anything, but all solutions other than a straight beam through the fuselage introduce large bending moments and a heavy structure - for which advantage? On ground the wings hang off the fuselage, in the air the fuselage hangs off of the wings. Easy to snap off at the fuselage if not going straight through. $\endgroup$
    – Koyovis
    Jun 2, 2017 at 8:30
Just to add a very basic consideration to the already good answers here.
While there may be minor advantages of having the vertical tail symmetry, there is no actual symmetry in the vertical plane for any airplane, simply because any airplane needs to produce lift - which is the biggest aerodynamic force. The 'ideal' Sears–Haack body is ideal only for drag, without considering the need for lift.
This makes the airflow non-symmetric in vertical plane, and thus the optimal body will not be symmetric (even from the purely aerodynamic standpoint, before we consider spars etc.).
A high wing, for example, is aerodynamically the most efficient in most cases. It has positive interference with fuselage and will often have less drag than the equivalent middle wing.
Even on XB-42 you may notice that the horizontal tail is placed high, above the wing. This is usually done to reduce the effects of the downwash from the wing.
    $\begingroup$ I thought horizontal stabilizers were usually a bit higher than the wings in order to get "clean airflow" and prevent deep stall. Maybe this is the same thing? The only way I know to avoid this is to make the wing non-lifting (no camber) for the first, say, 2 meters out from the fuselage, and the horizontal stabilizers extend the same distance. Obviously that's a bit of an exotic solution and probably not worth it. $\endgroup$
    – DrZ214
    Oct 10, 2016 at 3:44
    $\begingroup$ The airflow is never quite "clean" for the tail. There are quite a number of effects associated with the wing downwash: reduced local AoA (which varies with lift); then delay of this variation (which has a small damping effect); reduction of airspeed; etc. Only perhaps a T tail with a low wing is more or less "clean" in normal flight, but this is exactly the configuration that may suffer from "deep stall" - it becomes "unclean" at the worst moment. With some cleverness the wing/tail interference can be used to a benefit (e.g. An-124), but this works in a limited range of flight regimes. $\endgroup$
    – Zeus
    Oct 10, 2016 at 4:53
You're right that there aren't any production aircraft with a 'symmetric' design. But quite a few experimental aircraft have them, especially the tail sitter VTOL ones- note that even they aren't perfectly symmetrical, showing the issues.
Convair XFV Pogo
Convair XFV Pogo By No information - US Navy, Public Domain, Link
Lockheed XFV 1
Lockheed XFV 1 Public Domain, Link
Looking at these aircraft alone, we can see some of the issues we would face in these aircraft.
  • The main spar would have to pass through the fuselage, which will severely limit the uses of these aircraft- it would be extremely difficult to use them in passenger and cargo carrying roles (Even if it is used, loading is going to be a problem unless you open the cockpit upward).
  • Having a lower fin would cause problems. Unless you are going to take off vertically (which is rarely preferred), the landing gear size has to be increased as with severe limitation in the rotation angle during takeoff and attendant problems. This will lead to weight issues and runway restrictions.
  • Then there are maintenance problems- if you have to change the engines (which for symmetry, has to be inside the fuselage), the only way is to remove the bottom tail (kinda like the harrier, whose wing has to be removed).
Any aircraft has to be designed for production and operation. These issues are too difficult to justify the use of symmetrical aircraft except for very specific purposes- like the XB-47 and Do-335 designed for speed and the XFV and XFV 1 designed for vertical take off.
For any other aircraft, the required tradeoffs would be too costly to justify. Why tinker with what's working for something that offers little practical benefits (flight controls are doing fine without symmetry; even if there's a problem, modern autopilots can handle them fine) or just because it looks good on paper?
  • $\begingroup$ Ohh yes I know I've seen the Pogo before. Never seen the XFV 1. But of course the Pogo's empannage isn't symmetric, because it's using a delta wing. It looks like the XFV 1 uses a symmetric X tail tho, just like I envisioned! Tail-sitters are a whole nother genre of aircraft which, in my mind, are not truly fixed wing. Nor are they even tilt-rotors. They're just a whole new genre with its own quirks. $\endgroup$
    – DrZ214
    Oct 9, 2016 at 6:20
  • $\begingroup$ @DrZ214 I agree, though i have to add that if you want a really symmetric aircraft, you have to look at a missile or a rocket. I'm pretty sure that's not what you wanted to discuss about. $\endgroup$
    – aeroalias
    Oct 9, 2016 at 6:23
  • $\begingroup$ You're right. I don't wanna examine rockets except possibly to analyze/compare the symmetric shape. I want something that takes off and lands. If the biggest problem is tail strikes or rotation at takeoff, then canards can solve that by pushing the nose up and pivoting the aircraft at its tail wheel. $\endgroup$
    – DrZ214
    Oct 9, 2016 at 6:47
