Why do some helicopters have some type of hook sticking out of the bottom of the tail section, my guess is that it is used to secure the helicopter to carrier deck, but i'm not sure, so I am going to ask in case I'm wrong.
Source: www.b-domke.de
Sign up to join this communityWhy do some helicopters have some type of hook sticking out of the bottom of the tail section, my guess is that it is used to secure the helicopter to carrier deck, but i'm not sure, so I am going to ask in case I'm wrong.
The device is often referred to as a tail rotor guard or tail skid, which hints at its purpose.
Helicopters that have tail rotors that sweep below the tail boom are usually equipped with this guard to prevent the tail/rotor from striking the ground during landing, both during a rolling landing or a vertical landing. It is especially useful for landing off-field where the terrain may not be flat near the tail rotor.
Many rotorcraft, both general aviation, transport, and military have this feature, and it may even be required by regulation (see 14 CFR 29.411 for transport category rotorcraft).
Here is the tail rotor guard on a Robinson R44:
Source: Airport-Data.com
While technically the same as in the original question, I do not believe the R44 rotor sweeps below the vertical fin. The Red/White guard protects the blade while the "stick" on the fin keeps the fin from contacting the ground. It may be possible to contact the rotor if landing on soft earth or tall grass...
You can search through Google Images to find many examples of rotor guards.
(a) It must be impossible for the tail rotor to contact the landing surface during a normal landing.
$\endgroup$ – Ron Beyer Oct 5 '16 at 16:03
