How do you control yaw in aircraft with a stick control?
It seems like forward and back are used for pitch, and left/right are for roll, so where is the yaw?
Sign up to join this communityHow do you control yaw in aircraft with a stick control?
There are a few ways that yaw control is achieved.
Airplane Flying Handbook pg 2-1
The first application to control yaw unsuccessfully was the development of gears and linkages that will control both roll and yaw with the pilot stick. It was quickly discovered that there are cases where you may need to use the controls separately.
Yaw damper is an electronic device that sense yaw rate and will provide inputs to the rudder to keep the airplane coordinated.
https://www.gulfcoastavionics.com/images/products/3552/detail/detail.jpg
