10
Are (or were) there any operational aircraft that don't have horizontal and vertical stabilizers or canards? If so, what's the effect on how they fly?
    $\begingroup$ You are asking if you can take any aircraft and remove its elevators/stabilizers and it would still fly normally? No, absolutely not. $\endgroup$
    – Ron Beyer
    Oct 4, 2016 at 16:09
    $\begingroup$ Possible duplicate of What is the function of the tail section on a fixed-wing aircraft? $\endgroup$
    – fooot
    Oct 4, 2016 at 16:57
    $\begingroup$ @RonBeyer That's not what is being asked at all. The question is clear. Are there, or were there any aircraft that don't have stabilisers or canards. The short answer to which is yes. $\endgroup$
    – Simon
    Oct 4, 2016 at 18:41
  • $\begingroup$ @Simon Given the original title and text, its not so clear, which is when the comment was made. $\endgroup$
    – Ron Beyer
    Oct 4, 2016 at 20:02
    $\begingroup$ You always need to have pitch, roll and yaw control. Vertical and Horizonal stabilizers are just a solution. Flying wings have another solution. $\endgroup$ Oct 4, 2016 at 22:19
4 Answers 4
15
Depending on how you classify the control surfaces, the B-2 Spirit does not have a horizontal stab, since it is a "flying wing" design. As you have changed the question, the other part of the answer is that the flying wings have been able to get by without vertical stabilizers as well, at least in the case of the B-2. It uses both spoilers ("split brake rudders") and thrust differential to accommodate the lack of a vertical stabilizer.
Northrop had investigated several means of applying directional control that would least infringe on the aircraft's radar profile, eventually settling on a combination of split brake-rudders and differential thrust ~ Sweetman, Bill. "Lockheed Stealth" (2005) ISBN 0-7603-1940-5., p. 73
(And as with flight controls in general on the on B-2, that's helped a lot by its fly by wire flight control system).
As the Germans discovered in their flying wing aircraft (Ho229), and the USAF in the YB-35 and YB-49 programs, flying wings have inherent instability, even though some early biplane "flying wing designs" were stable enough to fly. (Dunne). enter image description here
The B-2 has a fly by wire system to retain stability and handling qualities so that it does not have to make tradeoffs (loss) in performance that earlier flying wing designs did in order to make the design "stable enough."
What the elevator/horizontal stab do for conventional aircraft is allow for longitudinal control (pitch control). If you don't choose to use that conventional method, the "effect" is that your design must find another way to establish longitudinal control and stability or the aircraft risks being unstable in that axis.
Likewise with vertical stabilizers, your design has to address stability in the yaw axis if you want to make it without a control surface acting in that axis.
    $\begingroup$ Can you expand a bit on how the B-2 achieves yaw stability? i.e. what actuators does this smart fly-by-wire use to control the plane - is it just differential thrusting on the engines? $\endgroup$
    – E.P.
    Oct 4, 2016 at 21:48
  • $\begingroup$ That, and differential control surfaces. Basically. There's more to it than that, but that's the gist of it. There are a total of 9 independently movable control surfaces at the trailing edge of the wing. 3 pairs of elevons, 1 pair of split brake-rudders, and an elevator in the middle. $\endgroup$ Oct 4, 2016 at 23:49
  • $\begingroup$ @E.P. Edited in. $\endgroup$ Oct 5, 2016 at 0:27
  • $\begingroup$ @E.P.: You can see in the picture above. The split ailerons at the end of the wings are called drag rudders - differentially increasing drag on either side of the wings. Opening both drag rudders shifts centre of drag backwards instead effectively acting as vertical stabilisers as well (think about how badminton shuttlecocks achieve directional flight) $\endgroup$
    – slebetman
    Oct 5, 2016 at 3:41
Based on the wording of your question, the Flying Wing design would qualify. These aircraft do not have proper "tail" stabiliser sets and they still fly.
Among the earliest aircraft to fly were the models of Alphonse Pénaud, and they flew without a vertical tail. The rubberband-powered pusher propeller was sufficient for stabilization. Admittedly, they did not need to maneuver.
Pénaud's Planophore
Pénaud's Planophore (picture source). The spinning propeller replaced the vertical tail.
After Friedrich Ahlborn published a study on the aerodynamic qualities of the Alsomitra seed, Igo Etrich and Franz Wels designed a glider inspired by the seed's shape. This flew in 1906 and was the first man-carrying flying wing. As a glider, it could not rely on a pusher propeller for stabilization; instead it copied the sweptback outer wing of the Alsomitra seed with its upswung trailing edge.
Flying wings use reflex airfoils and/or wing sweep in combination with reduced incidence in the outer part of the wing (washout) for stabilization. Yaw stability is provided by sweep and pitch stability by the reduced incidence in the outer/rear part of the wing. In general, avoiding tail surfaces altogether can still result in stable aircraft but reduces damping a lot. The result is a flyable but problematic design.
Hangglider in flight
No self-respecting hang glider designer would think twice about adding tail surfaces (picture source).
A third way of avoiding a conventional tail is the V-tail, which was invented in 1930 by the Polish engineer Jerzy Rudlicki.
Lazard ultralight with inverted V-tail
Ultraflight Lazard ultralight with inverted V-tail (picture source)
In the 1940s and 1950s, roll, pitch and yaw control was demonstrated through variable wing geometry, the aim being to eliminate the drag and normally negative lift of the tail.
When variable geometry wings were re-invented in the 1960s, the original purpose had been forgotten or discounted, and variable geometry was restricted to matching the wing's characteristics to different speed flight regimes, pitch and yaw control being performed by conventional tail surfaces.
As they had both the weight of wing hinges and actuators and the disadvantages of tail control surfaces, they were probably the worst of both worlds.
The experiments were restricted to remote controlled prototypes, to prove the principle before developing manned aircraft (their designer was distressed by the loss of life from some earlier inventions). Apparently, money issues and politics stopped further development at the time in the UK, though this page suggests Nasa studied the idea, finding some difficulties including unexpected drag. Whether those difficulties could be solved now ... I've no idea. I'm no expert, just an observer, so I'd be interested to hear any more about these ideas.
Pity, the Swallow (source here) would have been a nice looking machine. enter image description here
Sources: Life of Barnes Wallis
This site is temporarily in read-only mode and not accepting new answers.
