While taking a practice test, I needed to calculate the magnetic heading between two airports. Most of the time I run into a problem, the map will provide me with isogonic lines with the East/West variation visible. But in at least one or more questions, the isogonic line is either not shown, or the numbers are not visible.
Using the protractor to calculate the angle on the isogonic line using the latitude/longitude lines doesn't seem to give me the correct number either.
Does anyone know what I am doing wrong or how I can come to a correct answer?
Problem
(Refer to figure 23.) What is the estimated time en route for a flight from Claxton-Evans County Airport (area 2) to Hampton Varnville Airport (area 1)? The wind is from 290° at 18 knots and the true airspeed is 85 knots. Add 2 minutes for climb-out.
Valid Answers:
- 44
- 39
- 35
Update: I added an actual sample problem. Assuming the only information I am able to work with is the map, the question and my E6B (manual or electronic).
Update I found the original question that got this thread started:
(Refer to figure 24.) Determine the magnetic heading for a flight from Allendale County Airport (area 1) to Claxton-Evans County Airport (area 2). The wing is from 090° at 16 knots, and the true airspeed is 90 knots.
The correct answer: 209°
The solution given in study mode: With a plotter, measure the true course from Allendale to Claxton-Evans as 212°. Use a flight computer to find the true heading of 203°. Add variation of 6°W. 203°+6°=209°.
