I'm trying to get my commercial drone operators certificate. I already have a private pilot certificate, so from the FAA website, all I need to do is complete the "Part 107 small Unmanned Aircraft Systems (sUAS) ALC-451" course on faasafety.gov, then file some paperwork. But I can't find the course. Is there a direct link to it?
    $\begingroup$ The site is opening allright, though I'm not exactly sure how its related to aviation as defined in help center. $\endgroup$
    – aeroalias
    Sep 29, 2016 at 14:15
  • $\begingroup$ The home page is working ... I can't access the actual course page though. $\endgroup$
    – Arel
    Sep 29, 2016 at 14:16
  • $\begingroup$ faasafety.gov/search/… $\endgroup$
    – Arel
    Sep 29, 2016 at 14:17
  • $\begingroup$ Looks like its intermittently working. is this the correct course? $\endgroup$
    – aeroalias
    Sep 29, 2016 at 14:20
  • $\begingroup$ I used the site to get my drone cert on Monday and it was working fine for me (around 10am eastern) as was IACRA $\endgroup$
    – Dave
Even when faasafety.gov is working without issue, the course can be difficult to find with the site's search feature. The Part 107 Small Unmanned Aircraft Systems (small UAS) course is presently available from this direct link: Part 107 Small UAS Course.
Note that you will have to be logged in to do the course. If you follow that link and are not logged in to faasafety.gov, log in and then go to that link again.
Note also that faasafety.gov currently seems to be experienceing occasional technical issues, either due to maintenance or traffic volume. The link may not work reliably at present.
