As we all know from our instrument training, the MOCA is:
MINIMUM OBSTRUCTION CLEARANCE ALTITUDE (MOCA)- The lowest published altitude in effect between radio fixes on VOR airways, off-airway routes, or route segments which meets obstacle clearance requirements for the entire route segment and which assures acceptable navigational signal coverage only within 25 statute (22 nautical) miles of a VOR.
Whereas the MEA is:
MINIMUM EN ROUTE IFR ALTITUDE (MEA)- The lowest published altitude between radio fixes which assures acceptable navigational signal coverage and meets obstacle clearance requirements between those fixes. The MEA prescribed for a Federal airway or segment thereof, area navigation low or high route, or other direct route applies to the entire width of the airway, segment, or route between the radio fixes defining the airway, segment, or route.
(Both quotes taken straight from the Pilot/Controller Glossary)
The only difference in language is the bit about 22 miles from a VOR.
Therefore, when you're within those 22 miles, there's no practical difference between a MEA and a MOCA, right?
If that's true, why is there an 1800 foot difference between the MEA and the MOCA within 22 miles of the PMM VOR on V84?
