Based off this question, I got interested on how contrails compare between jet engines and piston powered engines.
Seeing images like these from WWII, I am wondering what the significant differences are in the contrails made by the two different kinds of engines. enter image description here
Image Source
As far as the contrails are considered, there is little difference between the ones formed by different aircraft. Contrails form when the ambient air (which is usually cooler) mixes with the hot, humid exhaust. This usually happens at high altitudes.
One difference may be that the different particulate matter (eg. soot) emitted by both the engines may be different. These particulates act as condensation nuclei for the water vapor at high altitudes. From FAA's Aviation Emissions, Impacts & Mitigation A Primer:
The soot particles at cruise altitudes interact with other chemicals such as sulfuric acid and nitric acid to form small particles that act as nucleating sites for condensation of water vapor present in the upper atmosphere under certain conditions to form larger particles to form condensation trails or contrails, for short.
While I'd venture that the (older) piston engines emitted more of these particulates, the only study i could find online indicates that the particulate emission is similar in case of gas turbine engines and aviation piston engines using unleaded petrol (while significantly higher in case of older, leaded gasoline, as was used during WWII).
Piston Vs Gas turbine 1
Piston Vs Gas turbine 2
Both images from Microphysical and Chemical Properties of Nanoparticles emitted by Flight Engines by Claus Wahl, Theo Rindlisbacher and Lars Hjelmberg
This would mean that the effect of particulate emissions on contrail formation would've been the same. However, there is another factor- altitude. In general, the (modern) jet engines fly much higher than their piston engines counterparts- the contrails you see in WWII bombers are formed by supercharged engines flying at high altitude to escape from AA defenses. Also, as @ymb already noted, the size/shape and number of exhausts also vary between the piston and gas turbine engines.
Though the mechanism of contrail formation is the same in the piston and gas turbine engines, the difference between them lies in their size/shape per engine and their operating envelope.
I can't find studies comparing both. Same for studies just on piston engine contrails. Most probably such a study during WWII would have been of trivial importance.
So I can just speculate. An individual contrail will be smaller in size due to the exhaust size. But also numerous small ones per engine, based on the number of exhausts.
Those engines were beasts, two-speed two-stage intercooled superturbocharged, so they went through a considerabe volume of air, contributing to comparable moisture as a combustion byproduct.
The exhaust gas was also fast, contributing to condensation as the pressure would drop.
The Merlin consumed an enormous volume of air at full power ... with the exhaust gases exiting at 2,100 km/h—Wikipedia
So, numerous tiny contrails contributing to either a streaked contrail as the images would suggest. Or when the conditions are right, they combine into one contrail per plane.
    $\begingroup$ The Merlin also consumed 40 liters of oil per hour. This oil went into the exhaust stream as a fine mist, producing lots of condensation nuclei. Only a little water from the combustion process was needed to turn almost-saturated air into a thick cloud. $\endgroup$ Sep 25, 2016 at 15:16
