12
It occurs to me that jet engines are very heavy objects operating at high RPMs. This must have a very high angular moment and thus a high gyroscopic force.
This would restrict rotation when trying to yaw or pitch. Rolling, however, would not be effected.
How big of a problem is this? I imagine it is a concern to military aircraft as they want to be as maneuverable as possible. But I'm very interested in commericial efficiency too. I wonder if the giant A380, for example, had to be given greater elevator and rudder authority to help it pitch up at takeoff.
Note: all engines rotate but I'm assuming the jet engine will have by far the highest angular moment due to the weight of their turbines and compressors. Turbofans with high bypass ratio probably have the greatest gyro forces due to their huge fan in addition to heavy spinning spools.
(Presumably, contra-rotating engines would have zero gyroscopic forces.)
  • $\begingroup$ I am pretty sure this is a duplicate and there is already great answer explaining it is not generally noticed in jets (it is noticed in props) except the Rolls-Royce Pegasus used in Hawker Siddeley Harriers, which has low and high pressure shafts rotating in opposite directions to reduce gyroscopic effects. The related question search being as bad as it is I can't find it now though. $\endgroup$
    Sep 18, 2016 at 7:00
5 Answers 5
15
Yes. The more so the higher the inertia and speed of the rotating masses and the lower the control authority. While the gyro forces of a jet are negligible in regular flight due to the high damping provided by the wings and tail, in hover they can become dominant. The Bristol-Siddeley Pegasus engine of the Kestrel, Harrier and AV-8B jump jets needs to have the low pressure spool run in opposite direction of the high pressure spool to balance its gyro effects. If that would not be the case, a yawing motion would produce a pitching motion, and vice versa. When you sit on a jet, the thrust of which is equivalent to your weight, tilting this jet fore or aft only slightly will produce a quick shift of your location, so any maneuvering in hover will become extremely hard.
USMC AV-8B Harrier in hover
USMC AV-8B Harrier in hover (picture source, © Richard Seaman 2001)
Generally, contra-rotation of engine parts has been used to reduce gyro effects. They first became an issue with rotary engines in WW I. A rotary engine has its crankshaft fixed to the airplane, and both the cylinder block and the propeller rotate. This gives better cooling at low speed and produces a flywheel effect, so the engine runs more smoothly. But when you yaw, the gyro effect pitches the aircraft up or down, so any precise maneuvering becomes very hard.
With the increasing engine power in 1916 and 1917, this effect became so severe that geared engines were developed where the cylinders rotate in one direction and the propeller in the opposite direction. As a consequence, the propeller had only half the RPM in air as it had with the cylinder block. This resulted in great propeller efficiency, but also big propeller diameters, so airplanes with those engines needed a high landing gear. Below is a picture of a Roland D XVI with a Siemens & Halske III contra-rotating rotary engine from 1918. This was an excellent fighter aircraft for its time with almost no gyro coupling.
Roland D XVI
Roland D XVI (picture source)
Generally, jet engines are sensitive to maneuvering: Changing load factors will bend the spools between their bearings such that the tip clearance of both the turbine and the compressor need to be big enough to avoid contact under g forces, or when rolling with a wing-mounted engine. Every engine manufacturer will publish a load factor envelope within which the engine is safe to operate. Widening this envelope will reduce engine efficiency because the gaps between the rotating parts and the engine housing need to grow with the maximum load factor.
  • $\begingroup$ what an amazing solution this contra-rotating rotary engine is $\endgroup$
    – user721108
    Sep 12, 2022 at 10:18
The answer is yes. Gyroscopic forces are a factor on propellor driven aircraft, but generally not noticeable on a stable ('God Fearing') aircraft in cruise flight.
However gyroscopic effects do become noticeable in several areas of a propellor driven aircraft's flight envelope. One of the best known areas are in dramatic changes in pitch attitude at low speeds. Tail wheel aircraft are particularly sensitive to this during the takeoff roll. Fast transitions from a three point attitude to a wheel attitude during ground roll will cause noticeable and unwanted yaw inputs due to gyroscopic precession in addition to changes in P-Factor. During takeoff in a typical tail wheel airplane with a propeller which rotates clockwise when viewed from the cockpit will yaw left when the tail is lifted during the takeoff roll and requires right rudder to counteract the gyroscopic precession. Likewise during a wheel landing, precession from the propellor will cause the tail to yaw right as the the tail wheel settles onto the runway and requires left rudder to counteract.
Advanced or unlimited aerobatic aircraft often fly gyroscopic maneuvers such as the Lomcevak, which utilize gyroscopic precession to induce tumbling forces into maneuvers. Even loops, hammerhead stalls, etc require a significant rudder or other control inputs to counter precession from the prop at slower speeds.
    $\begingroup$ "God fearing aircraft" is now part of my training repertoire. Love it. $\endgroup$
    – acpilot
    Sep 18, 2016 at 0:39
  • $\begingroup$ Thanks, but just so you know, I'm interested if these things are significant for any engine type. Not just piston prop and turboprob, but turbojet and turbofan too. $\endgroup$
    – DrZ214
    Sep 18, 2016 at 0:43
  • $\begingroup$ @DrZ214: It's the props that cause most of the gyroscopic effect. The engines themselves are too small to matter. Even jet engines. In fact, one of the big advantages of jet engines touted by early jets is the lack of gyroscopic effects. (in theory, it doesn't lack it but the pilot can no longer notice it) $\endgroup$
    – slebetman
    Sep 18, 2016 at 1:48
  • $\begingroup$ "from a three point attitude to a wheel attitude"? Is that statement missing a word? $\endgroup$
    – user
    Sep 19, 2016 at 15:30
  • $\begingroup$ @MichaelKjörling I assumed that "wheel attitude" meant that the tail was no longer dragging. I could be quite wrong. $\endgroup$
    – FreeMan
    Sep 21, 2016 at 19:38
One area not yet mentioned where gyroscopic effects are significant (in both jets and props) is spin. (In English it sounds almost tautological :) Spin always involves significant angular velocities - while having very limited control authority.
(In a way, this is similar to the effects on aerobatics mentioned by Carlo Felicione.)
Due to gyroscopic effects of the engine(s), most aircraft have different left and right spin characteristics. To the point that, say, left spin may be almost unrecoverable while right spin would be easily recoverable. This also applies to initiating the spin: the aircraft may tend to enter spin in one direction more willingly than in the other.
You do see gyroscopic effects when you look at WW1 fighters. Quote from the Wikipedia Article on the Sopwith Camel:
The type owed both its extreme manoeuvrability and its difficult handling to the close placement of the engine, pilot, guns and fuel tank (some 90% of the aircraft's weight) within the front seven feet of the aircraft, and to the strong gyroscopic effect of the rotating mass of the cylinders common to rotary engines.
For comparison, a 777-300ER has a max take-off weight of 775,000 pounds (reference), while one GE90-94B engine weighs 16,644 pounds, not all of which would be rotating. So if we assume half the weight is rotating mass (probably high, but I don't know), the rotational mass of both engines is only about 2% of the total mass.
Finally, I'm not aware of any contra-rotating jet engines, so that would imply the forces aren't too noticeable.
Yes, gas turbines can have noticeable gyroscopic effects at low airspeeds. The Harriers RR Pegasus has contra-rotating spools for that reason.
    $\begingroup$ This answer would be improved with referenced or citations to support it. $\endgroup$
    – Ralph J
    Sep 12, 2022 at 0:20
  • $\begingroup$ Not to be pedantic, but I need to be pedantic about this. Many of the comments and answers on this post are talking about the effect of the engine's TORQUE on the aircraft, which is distinctly different from gyroscopic precession. We fall too easily into the habit of calling any resulting artifact of a heavy, fast-turning object "gyroscopic effect" when gyroscopy is only one of several factors and usually not the most significant. $\endgroup$
    – Max R
    Sep 14, 2022 at 5:17
