I was looking at the difference between rotorcraft and powered-lift and every example I saw was a military application (Osprey or Harrier or F35)
The FAA defines powered-lift:
Powered-lift means a heavier-than-air aircraft capable of vertical takeoff, vertical landing, and low speed flight that depends principally on engine-driven lift devices or engine thrust for lift during these flight regimes and on nonrotating airfoil(s) for lift during horizontal flight.
I was wondering if there were any small, personal powered-lift aircraft that one might get their private pilot license in the way people get a ASEL certificate in a 172.
I know there is the AW609, but that is targeted towards the business market with a very specific niche.
    $\begingroup$ The Harrier has some private owners and could be considered a "small" powered lift aircraft. The issue I see though is that powered lift is somewhere between a helicopter and an airplane, and is probably not the best choice of aircraft for primary training. $\endgroup$ – Ron Beyer Sep 7 '16 at 20:15
I suppose some kinds of roadable aircraft aka 'flying car' designs would qualify under the powered lift category. One example which nearly escaped the prototype stage was the Moeller SkyCar.
But beyond the Agusta AW609, I cannot think of any other powered lift category aircraft which are, or may be soon, available for sale to the general public.
    $\begingroup$ The first Powered Lift pilot certificates were awarded to V-22 Osprey test pilots in 1997, I'm not sure if the certificate applies to experimental category aircraft though. The only reference I can find about it in the FAR's (61.163) applies to ATP and commercial certificates. $\endgroup$ – Ron Beyer Sep 7 '16 at 21:14
  • $\begingroup$ Interesting. I think the V-22 Osprey is such a neat design, it makes sense that it required a whole new class of certificates. $\endgroup$ – Canuk Sep 7 '16 at 21:51
  • $\begingroup$ Looks like the Terrafugia TF-X (looks like it's currently in dream phase) might be in this class. (terrafugia.com/tf-x) $\endgroup$ – Canuk Sep 7 '16 at 21:52
  • $\begingroup$ Moller is still around and still working on prototypes, though whether they can bring something to market is questionable. $\endgroup$ – Michael Hampton Sep 7 '16 at 23:03
