I have recently taken up flying again in the UK, and although very little has changed in the 10 years I have been inactive, the one area which seems to have changed is in the en-route services available to pilots.
It used to be the case that you could request a Flight Information Service (FIS) and a Radar advisory (RA) service - I seem to recall there being one other which I never used, which I cannot quite remember the name of.
I believe the FIS is now referred to as a "Basic" service, is this assumption correct? Does it vary in any material way from the defunct FIS?
What other services are available to GA pilots in uncontrolled airspace? Where do I find the details of stations and what service(s) they provide?
  • $\begingroup$ Some information here: Services are Basic Service, Traffic Service, Deconfliction Service, Procedural Service. Also this flyer. $\endgroup$
    – mins
    Aug 30, 2016 at 9:02
    $\begingroup$ Thanks @mins - If nobody feels llike writing up a good answer I'll do so from the official sources when I get time. I think this is a useful Q/A to have here at aviation.se $\endgroup$
    – Jamiec
    Aug 30, 2016 at 9:06
According to UK AIP ENR 1.1 "General Rules", chapter 2 "UK Flight Information Services" the UK FIRs meet the ICAO requirements with the following Flight Information Services (FIS): Basic Service, Traffic Service, Deconfliction Service and Procedural Service.
This is an extract of the contents of the chapter:
Basic Service
Provides advice and information useful for the safe and efficient conduct of flights. This may include weather information, changes of serviceability of facilities, conditions at aerodromes, general airspace activity information, and any other information likely to affect safety. The avoidance of other traffic is solely the pilot's responsibility.
Basic Service is available under IFR outside controlled airspace in any meteorological conditions, or under VFR. A pilot may change heading, route, or level without advising the controller. A controller will not issue specific heading instructions; however, generic navigational assistance may be provided on request.
Traffic Service
Traffic Service is a surveillance based ATS, where in addition to the provisions of a Basic Service, the controller provides specific surveillance derived traffic information to assist the pilot in avoiding other traffic. The avoidance of other traffic is solely the pilot's responsibility.
Traffic Service is available under IFR outside controlled airspace in any meteorological conditions, or under VFR.
A Deconfliction Service is a surveillance based ATS where, in addition to the provisions of a Basic Service, the controller provides specific surveillance derived traffic information and deconfliction advice. A Deconfliction Service shall only be provided to flights under IFR in Class G Airspace, irrespective of meteorological conditions.[...] A controller will provide traffic information, accompanied with a heading and/or level aimed at achieving a planned deconfliction minima.
Procedural Service
A Procedural Service is a non surveillance ATS where, in addition to the provisions of a Basic Service, the controller provides instructions, which if complied with, shall achieve deconfliction minima against other aircraft participating in the Procedural Service. Neither traffic information nor deconfliction advice can be passed with respect to unknown traffic. A Procedural Service shall only be provided to flights under IFR, irrespective of meteorological conditions. [...] the pilot remains wholly responsible for terrain clearance at all times. [...] A controller will provide deconfliction instructions by allocating levels, radials, tracks, routes, time restrictions, approach clearances and holding instructions, or use pilot position reports, aimed at achieving a planned deconfliction minima.
