I've always heard that complying with a TCAS II Resolution Advisory is a required action for pilots qualified and operating an equipped aircraft. I am not familiar with the regulatory basis for this, though. I'd like to get a bit more specific with the context. For aircraft operating under 14 CFR 91, is there a regulation that can be referenced?? For aircraft operating under 14 CFR 135, is there a regulation that can be referenced? And what about for 14 CFR 121?
I'd also like to know if there are exceptions to any regulatory requirements.
This answer mentions that aircraft must respond within 6 seconds. I believe the source is AC 120-55C but I'm not totally sure.
  • $\begingroup$ It's part of the FCOM and QRH from manufacturers. FAA ensures operators include this in their SOP. Airbus has replaced previous "should... unless..." by "must" follow RA. See page 25 of TCAS Recommendations $\endgroup$
    – mins
    Aug 20, 2016 at 22:17
  • $\begingroup$ If not elsewhere, Ops Spec will probably be the regulating requirement outside of Part 91. $\endgroup$
    – J W
    Aug 21, 2016 at 14:36
The requirement to respond to the TCAS II resolution advisory is somewhat indirect. one key fact is that any TCAS installation has to be approved:
14 CFR §91.221 Traffic alert and collision avoidance system equipment and use.
(a) All airspace: U.S.-registered civil aircraft. Any traffic alert and collision avoidance system installed in a U.S.-registered civil aircraft must be approved by the Administrator.
(b) Traffic alert and collision avoidance system, operation required. Each person operating an aircraft equipped with an operable traffic alert and collision avoidance system shall have that system on and operating.
Key points here: 1. The installation must be approved. 2. If it's installed, it has to be used.
From Part 121:
14 CFR §121.356 Collision avoidance system.
Effective January 1, 2005, any airplane you operate under this part must be equipped and operated according to the following table: {Detail omitted}
This says anyone under Part 121 must have A TCAS installed and operating.
If you go back to Part 21, you can find that the installation approval requires a Type Certificate, Supplemental Type Certificate, or an Amended Type Certificate.
Part of getting that installation approval is a requirement for Airplane Flight Manual (AFM) or an AFM Supplement. With regards to TCAS, the airworthiness approval is addressed by
AC 20-151B Airworthiness Approval of Traffic Alert and Collision Avoidance Systems (TCAS II), Versions 7.0 & 7.1 and Associated Mode S Transponders
Chapter 5 and Appendix A cover the requirements for the AFMS for TCAS.
While the AC is advisory, it is spelling out a means of complying with the rules, which in Part 23 (small A/C) and Part 25 (air transport) require a flight manual.
Elsewhere:
14 CFR §91.9 Civil aircraft flight manual, marking, and placard requirements.
requires operation in accordance with the limitations of the AFM.
In Part 121, airlines operate in accordance with their Op Spec, which will include similar rules.
And there is specific wording to address clearances and response to TCAS:
14 CFR §91.123 Compliance with ATC clearances and instructions.
(a) When an ATC clearance has been obtained, no pilot in command may deviate from that clearance unless an amended clearance is obtained, an emergency exists, or the deviation is in response to a traffic alert and collision avoidance system resolution advisory. However, except in Class A airspace, a pilot may cancel an IFR flight plan if the operation is being conducted in VFR weather conditions. When a pilot is uncertain of an ATC clearance, that pilot shall immediately request clarification from ATC.
(b) Except in an emergency, no person may operate an aircraft contrary to an ATC instruction in an area in which air traffic control is exercised.
(c) Each pilot in command who, in an emergency, or in response to a traffic alert and collision avoidance system resolution advisory, deviates from an ATC clearance or instruction shall notify ATC of that deviation as soon as possible.
This basically acknowledges that pilots will respond to an RA and that they should report it as soon as they can after the fact.
14 CFR 91 Appendix G Section 2 (g)
Traffic Alert and Collision Avoidance System (TCAS) Compatibility With RVSM Operations: All aircraft. After March 31, 2002, unless otherwise authorized by the Administrator, if you operate an aircraft that is equipped with TCAS II in RVSM airspace, it must be a TCAS II that meets TSO C-119b (Version 7.0), or a later version.
14 CFR 121.356
Effective January 1, 2005, any airplane you operate under this part must be equipped and operated according to the following table...
14 CFR 135.180
Unless otherwise authorized by the Administrator, after December 31, 1995, no person may operate a turbine powered airplane that has a passenger seat configuration, excluding any pilot seat, of 10 to 30 seats unless it is equipped with an approved traffic alert and collision avoidance system. If a TCAS II system is installed, it must be capable of coordinating with TCAS units that meet TSO C-119.
TSO C-119
Also see AC-120-55 for information about operational use and required training for parts 91, 121, and 135. Specifically Section 12 "TCAS Operational Use" outlines how the crew is required to respond to TA's and RA's. It is a few pages long so not appropriate to duplicate here.
    $\begingroup$ That refers to fitment -- not TCAS RAs taking priority over everything else (save flying into the ground) $\endgroup$ Aug 21, 2016 at 2:29
    $\begingroup$ If the operator is using TCAS, even as a supplemental fitment, the crew is required to receive training and operate as per AC-120-55 #12 "TCAS Operational Use". $\endgroup$
    – Ron Beyer
    Aug 21, 2016 at 2:36
    $\begingroup$ I think AC-120-55 section 12 is the answer the querent wants then $\endgroup$ Aug 21, 2016 at 3:15
    $\begingroup$ This answer does not answer the question. Question asks about a requirement for crew to respond to RAs, answer merely addresses requirements for aircraft equipment. $\endgroup$
    – J W
    Aug 21, 2016 at 14:31
    $\begingroup$ @UnrecognizedFallingObject Section12 of that AC repeatedly says should, and is not regulatory in nature anyway. This doesn't answer the question which is looking for a requirement to follow the advisories. $\endgroup$
    – Lnafziger
    Aug 22, 2016 at 16:44
