I've heard people say "unload the controls" or "unload the wing/propeller."
What does this mean exactly? It is usually followed by releasing back pressure on the elevators or starting/ending a turn.
  • $\begingroup$ Starting a turn will increase load, not unload. It's especially important in critical attitude dive recovery to level wings before pulling out. $\endgroup$
    – STWilson
    Commented Jun 10, 2017 at 16:04
Unload means immediately reduce the lift being produced by a lifting surface. You:
  • unload a wing by pitching forward
  • unload a propeller by pitching forward, reducing power, or flattening blade angle (increasing RPM)
The typical reason to "unload" is to provide greater a margin from a stall or to reduce torque on an engine.
The term unload is easily understood from a bicyclist's perspective. When a steep hill flattens or a bike is shifted into lower gear, the bicyclist experiences unloading.
In conventional aircraft, control force (called stick force gradient) exists to inhibit pilot over-control. Control force is proportionate to the lift being produced and to aircraft speed. Therefore, to say "unload the controls", is the same as saying to "unload the lift on that surface".
  • $\begingroup$ Great explanation. $\endgroup$ Commented Jun 11, 2017 at 1:41
When maneuvering the aircraft by deflecting the control surfaces with the stick, the wing with the downward aileron and the tail will generate additional lift, which increases the load on that wing (using the ailerons) and on the tailplane (using the elevator).
Unload the controls is a request to neutralize the pressure on the controls. Usually this means bringing the stick back to the center position, reducing the controls surface deflection, the amount of lift generated, and therefore reducing the aerodynamic load on the wings and tailplane.
When you are manipulating the airplane, for example in a turn, you're increasing the aerodynamic loading of the wings. In a 30-degree level turn, the loading is 1.3G, i.e. 1.3 times the weight of the aircraft in straight-and-level flight. In a 60 degrees level turn, the loading is 2G.
If the plane is flying with excessive aerodynamic loading for a continued amount of time, it can end up in a stall. This is because to achieve a higher loading, the angle of attack must be increased; eventually it may exceed the critical angle of attack. With a higher angle of attack, the airframe will also produce more drag, with slows the aircraft down.
Excessive loading can also lead to structural failure, as you are asking the wing / elevator structure to provide more lift, increasing the stress of the airframe.
"Unload the wings" is a general term meaning "to reduce the lift produced by the wings". You're asking too much from the airplane. The action to execute depends on the state of the aircraft. If you're in a level turn, reducing the bank angle reduces wing loading. If you're pulling up, easing back pressure on the yoke / stick reduces wing loading.
In aerial dogfighting, "unloading" means to ease back on the stick and allow the airplane to pick up speed. High-G loading bleeds off energy very quickly. A pilot must manage his energy during a fight. If he keeps making very sharp turns, the high aerodynamic loading of the airframe will slow the aircraft down; and slow moving targets are easy targets.
  • $\begingroup$ Excessive aerodynamic loading can lead to a stall. meaning the stall speed increases, right? $\endgroup$
    – Canuk
    Commented Aug 6, 2016 at 15:59
    $\begingroup$ @Canuk excessive aerodynamic loading does not lead to a stall. F/A-18s have no problem making 9G turns. Increasing the angle of attack beyond the critical angle is the only thing that can lead to a stall (by definition). $\endgroup$
    – rbp
    Commented Aug 6, 2016 at 16:48
  • $\begingroup$ you have it completely backwards. the AoA is defined as the angle between the chord of the wing and the relative airflow. As AoA increases, lift increases (until reaching the critical AoA). As lift increases, load increases. Not the other way around. $\endgroup$
    – rbp
    Commented Aug 6, 2016 at 19:26
  • $\begingroup$ @rbp I meant to say "if you intentionally load up the wing for a continued amount of time, you might end up in a stall", not "aerodynamic stall is a result of high wing loading", though my wordings might get readers confused. $\endgroup$
    – kevin
    Commented Aug 6, 2016 at 19:28
    $\begingroup$ Maybe you want to go back and fix it. and delete the comments that are wrong. Also note that velocity is also a factor, and that intention has nothing to do with it. $\endgroup$
    – rbp
