I would like to know the difference between when the center of gravity (CoG) is forward and aft? And high and low?
I already know that the lower the CoG, the greater the static lateral stability. A forward CoG is generally more stable than an aft CoG. So does this mean that a low CoG is the same as an aft CoG?
Note: If the effects of an AFT CG is not the same as Low CG, then what's the effect of each one of them or what's the difference between them?, and most importantly when is the CG is AFT or Forward?, and when is the CG Low or High?
    $\begingroup$ Welcome to the site! I've reworded your question but I may have got it wrong, so please correct it as needed. However, I'm not sure exactly what you're asking: obviously "low" doesn't mean the same thing as "aft", so are you asking if the effect of a low CoG is the same as an aft one? If you can explain a little more about what you mean I think it would be helpful. $\endgroup$
    – Pondlife
    Aug 5, 2016 at 16:30
  • $\begingroup$ Yes im asking if the effect of a low CG is the same as AFT CG and if not then what's the difference between them? $\endgroup$ Aug 5, 2016 at 16:50
    $\begingroup$ As a pilot, I've only used forward/aft CG. As a motorcycle rider, I've only used high/low CG. Knowing the difference between the two, I'm not really sure that a high/low CG change would even affect an aircraft unless it moved the CG forward or aft. Plus, I don't know what would really constitute a high or low CG in an airplane. I don't know that you could move the CG far enough within the physical limits of the aircraft to make a noticeable difference. $\endgroup$
    – Shawn
    Aug 5, 2016 at 17:33
  • $\begingroup$ @Shawn Are you talking about moving the CG up/down to make a noticeable difference? Because if you are implying a front/back won't either I'd suggest the next time you go flying to trim the airplane out then have your passenger slide the seat forward or back about 4 inches and watch what the plane does :) $\endgroup$
    – Ron Beyer
    Aug 5, 2016 at 17:36
  • $\begingroup$ @RonBeyer Talking about up/down in an airplane. Front/Back will most definitely affect the flight characteristics of the aircraft. $\endgroup$
    – Shawn
    Aug 5, 2016 at 17:37
I'm not sure I'm understanding what you're trying to get at, but let me try to answer the sentence:
Whether the CG is aft or forward refers to its position along the longitudinal axis of the airplane, that axis that runs from the aircraft nose to the tail. Usually if people refer to just "the CG" they're typically referring to the longitudinal position of the CG as that is generally the most critical. Boeing refers to the longitudinal axis measurement as the BA, balance arm, although the longitudinal CG is usually spoken of in terms of the percent of the mean aerodynamic chord.
Let's say you have a freighter with a single 10,000 lb pallet in it. If that pallet is in the forward most position capable of handling it, the longitudinal CG would be considerably more forward than if the pallet were in the aft most position. Very possibly in either instance the respective forward and aft CG limits would be exceeded. If a loadmaster said only, "I've got a forward CG," he might mean that the load is forward of the forward limit, or he might simply mean that the load is within the limit but more forward than he likes.
Now let's say that we split the 10,000 lb pallet into two 5,000 lb pallets, and we put one of them in that most forward position on the main deck and the other in the same longitudinal position on the lower deck. That wouldn't change the longitudinal CG because both pallets are at the same longitudinal position. However, it would change the vertical CG as measured along the vertical axis. Loadmasters on 747s don't have to worry about the vertical CG because there are no defined limits for it in 747 weight and balance manuals. Loadmasters on 767s, however, do as there are defined limits. If a 767 loadmaster says he has a high CG, he can mean that the maindeck load is too great given how much is in the lower deck. He also might mean that the vertical CG of the maindeck load itself is greater than 42" above the maindeck floor. Boeing refers to the vertical axis measurement as the WL, water line.
Though you didn't ask about it, there is a third axis, the lateral axis, extending from wing tip to wing tip so to speak. Boeing refers to the position along this axis as the BBL, body buttock line, and there are typically limits as to how far from the aircraft centerline the lateral CG can be.
  • $\begingroup$ In reference to the BBL, don't put all the pallets on one side of the plane! $\endgroup$
    – FreeMan
    Aug 5, 2016 at 20:15
  • $\begingroup$ @FreeMan Correct, however, it's surprising (at least to me), how tolerant of lateral imbalance some aircraft are, especially the 747. For an example, go to 747.terryliittschwager.com, scroll down to the bottom of the page, and select test load #6 to see what it takes to exceed the limit. $\endgroup$
    – Terry
    Aug 5, 2016 at 20:24
  • $\begingroup$ @Terry Thanks for your answer commander, i asked that question from the start to understand 2 of the factors that affect the static lateral stability of an a/c. which are: 1.High wing and Low CG, 2.High Keel and Low CG which i don't understand them much and would really appreciate it if you could lend me a hand and explain to me how do they work or affect the stability. Thanks : ) $\endgroup$ Aug 5, 2016 at 23:25
  • $\begingroup$ Reading about CG on a 747 I can't help but think of this tragic video from Afghanistan $\endgroup$
    – TomMcW
    Aug 6, 2016 at 1:18
  • $\begingroup$ @KarimElshawarby As I understand it, both configuration 1 and 2 that you refer to promote lateral stability (i.e. dampen rotation about the longitudinal axis) because they maximize the vertical distance between the CG and the vertical center of the sideways forces on the aircraft. Those sideways forces (the keel effect) thus have a longer moment arm to right the aircraft. See faa.gov/regulations_policies/handbooks_manuals/aviation/media/… and search on "keel effect'' and you'll find some good info. $\endgroup$
    – Terry
    Aug 6, 2016 at 1:53
Basically your question is a combination of two aspects that were already discussed in quite a lot of detail:
Stability is already explained pretty well in What does it mean for a plane to be aerodynamically stable?. The summary is that forward centre of gravity makes the aircraft more stable, but slightly less efficient, while aft centre of gravity makes it less stable.
The vertical position is then discussed in How do the Airbus Beluga's wing/control surfaces deal with its high center of gravity? In short, vertical position of centre of gravity is mostly irrelevant. The lift in straight and level flight acts on a line passing through centre of gravity and banks with the plane, so it can't create any moment. Only the lateral force in a side-slip can, leading to slightly lower yaw-roll coupling with high CoG, but one does not normally rely on yaw-roll coupling, so it is not very interesting.
The vertical position of the CG on an airplane and its effect on stability is going to depend largely on the position of the wings. A high mounted wing with a low CG on the fuselage will create a very stable aircraft about its longitudinal axis; a high CG on a low mounted wing will create dynamic instability about this axis. Many aircraft which are designed for maneuverability e.g. aerobatic aircraft, military fighters, etc. have a shoulder mounted wing where the center of lift lies very close to the center of gravity along the vertical axis creating neutral roll stability.
CGs in the forward range of their approved envelop develop good lateral stability but at the expense of more induced drag as the tailplane or canards are required to produce more lift to counteract the torque the CG creates about the center of lift. Aft CGs reduce induced drag but lead to lateral instability and can be quite dangerous in a stall or spin due to the diminished effectiveness of the tailplane.
  • $\begingroup$ Vertical position of the CoG is IRRELEVANT! $\endgroup$
    Aug 5, 2016 at 19:01
  • $\begingroup$ I also suspect you mixed up lateral and longitudinal stability. Longitudinal stability is stability in pitch, that is around lateral axis. As for lateral stability, it is not clear whether it should mean stability in roll or in yaw and that term does not seem to be widely used. $\endgroup$
    Aug 5, 2016 at 19:06
    $\begingroup$ @JanHudec I also thought that the vertical position of the CG was irrelevant. However, I recently had to change some weight and balance software to handle 767 freighters. Much to my surprise (and dismay as I had given them a low quote on what I would charge), I found that there were vertical CG requirements. Thanks to that, I'm working for less than minimum wage. LOL $\endgroup$
    – Terry
    Aug 5, 2016 at 21:17
