I know that an aircraft uses its own power (thrust) while taxiing to move forward. But how does it turn?
- Do the front wheels pivot?
- Do you simply apply more power to the left engine if you're trying to make a right turn?
If you do apply power to turn, how much power? Wouldn't it tip over the plane? And how do you do it on a single-engine or prop aircraft?
