Imagine I am in a straight down dive, at terrific speed, and if I wanted upward sharp turn and got the stick back far enough, would I stall (or spin)? Does normal laws apply when the aircraft nose is vertically down?
    $\begingroup$ This is called a secondary stall: stall the plane and began a dive. During the dive, pull up till you get a stutter. $\endgroup$
    – rbp
    Jul 17, 2016 at 17:00
12
Yes, always. Physics doesn't care much about the aircraft's attitude and cannot be switched into different modes.
While the nose points straight down, a stall is hard to achieve since no lift is needed - the weight is balanced by drag and inertia. However, when you pull abruptly and start to pitch up, the aircraft can stall while the overall attitude is still partially nose-down. If the pitch inertia is small, the rotation about the lateral axis will increase the angle of attack quickly while the flight path is still more or less straight down. At this attitude the stall angle of attack can be exceeded and the aircraft will stall. This is not unusual - pilots are routinely warned not to pull too hard after ending a spin. And yes, entering the next spin is entirely possible. This is especially likely when the sideslip angle has not been set to zero after ending the first spin. In most cases, this second, unintended, spin is in the opposite direction from the first spin because the pilot maintained his anti-spin rudder deflection for too long.
There have even been cases of supersonic spins.
A few details will help, though. A high pitch rate will delay the stall to an angle of attack up to 50% higher than the stall angle at zero pitch rate. Flying faster will increase the Reynolds number, so stall is slightly delayed when compared to the stall conditions at 1g. Both effects, however, will increase the wing root bending moment, and pulling out of a dive will run a real risk of breaking off the wings when you pull too hard.
Absolutely. Stalls occur when the critical angle of attack is exceeded, plain and simple. While it's easy to see this when the aircrafts nose is really high above the horizon it can actually occur at any attitude, even nose down or straight and level.
Angle of attack is determined from the oncoming relative wind and the reference line of the wing (the point from leading edge thru the trailing edge of the wing). So if you were to imagine the airplane headed completely nose down, the relative wind will essentially be coming from the ground. When you yank back on the control to change the airplanes path, momentum will keep the aircraft headed in the same direction (at least momentarily). At that point the wings may be level with the ground but the difference between the relative wind and the reference line will be enough to cause the aircraft to stall.
