I'm designing a small, light and portable flying wing UAV that will launch and land vertically via a Tilt-rotor system. I'm attempting to use the program XflrV5 but am having difficulty understanding the numbers. I'm a design and electronics guy, but a poor engineer.
The craft has a span of 6', root chord of ~8". Since it is a VTOL it does not need to fly slowly - below 15-20 MPH. I would like a top speed of ~100 MPH. the end product will be likely built with carbon fiber so compressibility shouldn't be a problem. After some reading I am tentatively using the s5020 airfoil but I'm not married to it.
My primary priority is forward flight efficiency, second priority is reasonable stability as it for recon use (forest fires, search/rescue military) but this can be mitigated by use of a stabilized camera gimbal. Maneuverability is a low priority if it has to be to accommodate the above items.
My question is with these parameters what type of wing design would work best and would sweep and twist be needed considering the speed envelope?
A UAV with a similar envelope would be the Boeing Scan Eagle as it is catapult launched and flown into a net for retrieval.
-------------------EDIT 1 -----------------------
I have included some pics of possible designs to help show some ideal designs to meet the portability requirement. Note: the outer 2' (660mm) of the wing will be removable for portability.
It would be a great help to hear your opinions which would be best.
Shallow delta with small tail High aspect swept wing inverse delta plank Scan eagle - high aspect thin wing
-------------------EDIT 2 -----------------------
A similar model to mine is the Firefly6... mine will have some improvements as well as a different market. I forgot to add that the AUW will be 6 - 7 lbs. (~3Kg)
    $\begingroup$ an earlier post by me was flagged as having too many questions so i reposted this one with a narrower focus. thanks! $\endgroup$ Jul 13, 2016 at 15:35
  • $\begingroup$ Looks good to me now Jeff. Let's hope that someone on here has the expertise to help you. Peter Kampf will probably pass on by soon... $\endgroup$
    – Simon
    Jul 13, 2016 at 17:55
I know, flying wings are cool. But once you have built and flown one, you get a more nuanced view. To find the right configuration, start with a look at your objectives. You want:
  • excellent performance and
  • an observation platform with good stability.
Now let's see what a flying wing will do for you. Apologies for the heavy use of technical terms; please follow the links for more verbose explanations:
  • It will have little pitch damping, so your airframe will wobble through the air with every gust or control command. You will need wing sweep to get at least a little aerodynamic pitch damping.
  • Depending on wing sweep, wing spar stiffness and pitch inertia, the frequencies of the wing bending oscillations and the fast period mode might converge within the desired speed range, resulting in flutter.
  • With a span of 2m and a root chord of 20cm the aspect ratio is above 10. If you sweep the wing, your low speed characteristics become outright nasty. I know, you will use engine power for take-off and landing, but once you fly a tight circle, you will bring the wing close to stall even at higher speed, and then a high aspect ratio swept wing will start to roll on its own and pitch up. In other words: It will become uncontrollable.
  • A reflex airfoil only produces lift in its forward part. The rear part produces a little downforce at high speed and proportionally much less lift than the forward part at low speed, so the whole wing will become less efficient. It will be better to reduce wing area and to use an airfoil with an excellent ratio of lift to drag.
My advice: Put part of the saved area at the end of the fuselage as a horizontal tail surface. This will give you ample pitch damping (goes up with the square of the tail surface's lever arm) and enables you to use a high-performance airfoil on a very small wing which produces much less drag than a flying wing of the same minimum speed. If you want good high-speed performance it is important to keep the wetted area at a minimum to minimize friction drag.
Now that you have expanded the question and added portability, let me propose something that would combine all three characteristics: The Leading Systems Amber. It was designed to fold to the size of a torpedo to be carried onboard Navy ships by pivoting the wing by 90° and folding the two tail surfaces forward. Combine this with a folding propeller and hand-launch it to avoid conventional take-offs.
Leading Systems Amber in flight
Leading Systems Amber in flight (picture source)
Landing was done by deep-stalling the aircraft. To quote from an article about Abe Karem in Air&Space magazine:
Most ingenious of all, Amber could be recovered by putting it into a “deep stall”—a feature used in free flight glider models to escape thermal updrafts and stay within flight time limits. The stall would bring Amber to “a near-vertical landing so it could be used from small ships, submarines or trucks/trailers,”
At least, this is what I would do: Build a scale model of Amber.
  • $\begingroup$ Hi Peter and thank you very much for your time. for some background, I own an RVJet which flies great but needs an enormously long landing approach due to a large ground effect ( Ive flown it 100 meters at 1 meter in height before it touched down). this is what spawned the idea for this plane. Im wondering if using a wing like this ( a slight delta) would qualify as your solution? thanks $\endgroup$ Jul 13, 2016 at 21:37
  • $\begingroup$ sorry for another comment... i am trying to use a tailless plane so it can be put inside of a backpack. thanks $\endgroup$ Jul 13, 2016 at 21:43
  • $\begingroup$ I have edited my original post and added some pics if that is OK to do...Jeff $\endgroup$ Jul 14, 2016 at 21:56
    $\begingroup$ @jeffdelvecchio: Yes, it's OK and helps me to understand that portability is also a design goal. Now the hardest question is how to combine the flying wing with a tilt rotor. That's not easy! $\endgroup$ Jul 14, 2016 at 22:20
  • $\begingroup$ Hi Peter, the Pixhawk autopilot can now handle the transitions fairly well and its getting better. The prop configuration is basically a tricopter layout where the 2 front props tilt forward/up and the 1 aft prop tilts port/starboard for hover yaw control and turns off in forward flight. there are other control schemes available and there are 2 similar models... one that is very similar is called the firefly6. thanks $\endgroup$ Jul 15, 2016 at 2:56
