-4
If an aircraft flies with it's belly facing the earth (or "Blue side up"), the how can it fly around the world without flying inverted?
  • $\begingroup$ Possible duplicate of Can large airliners do aerobatics such as loops? You might also want to ask some questions on physics.SE about how gravity works. $\endgroup$
    – Pondlife
    Jul 13, 2016 at 15:13
  • $\begingroup$ Because your frame of reference moves with you. $\endgroup$
    – Ron Beyer
    Jul 13, 2016 at 15:39
  • $\begingroup$ what is a "frame of reference"? $\endgroup$
    – thales727
    Jul 13, 2016 at 15:51
  • $\begingroup$ Possible duplicate of Do pilots adjust the aircraft's flight path to allow for the curvature of the Earth? $\endgroup$
    – fooot
  • $\begingroup$ @thales727 This is much better suited to a physics site. A frame of reference is a relative coordinate system. Just like "up" is the same in antartica as it is in the north pole, the difference is your frame of reference. In the image above, the FoR is something in space, like the moon. If you were in the aircraft, the FoR would be your place in the plane. By the way, FL430 is not considered "extreme low earth orbit" just like 8 inches off the ground isn't "ultimate low earth orbit". $\endgroup$
    – Ron Beyer
    Jul 13, 2016 at 15:53
