12
In section VII. Slow Flight and Stalls, page 54 of the Private Airplane ACS, the Skills section contains in part
$$\begin{array}{l|l} \bf{Skills} & \text{The applicant demonstrates the ability to:} \\ \hline \textit{PA.VII.A.S2} & \begin{align} \text{2. } & \text{Establish and maintain an airspeed, approximately} \\ & \text{5-10 knots above the 1G stall speed, at which the airplane} \\ & \text{is capable of maintaining controlled flight without activating} \\ & \text{a stall warning.} \end{align} \end{array}$$
During my primary training and when I took the practical test under the old Practical Test Standards, slow flight was conducted at minimum controllable airspeed with the stall horn blaring.
What are the motivation and supporting data behind this change to slow flight strictly above $V_{MC}$?
I attended the ACS webinar on June 25th. This is the response from Christopher Morris at the FAA. You can also read the FAQ on the FAA website.
If the pilot recognizes the stall warning and promptly makes an appropriate correction or airspeed adjustment, a momentary activation of the stall warning horn does not constitute unsatisfactory performance on the maneuver. As with other standards, the problem would arise from continual deviation from the standard, lack of correction, and/or lack of acknowledgment. The goal is to ensure that the applicant does not perform the maneuver with the stall warning activated.
The certification standard in 23.207 states for airplane certification testing, the stall warning must “begin at a speed exceeding the stalling speed by a margin of not less than 5 knots and must continue until the stall occurs.” This is the primary reason the suggested range above stall speed has moved from “3-5 knots” to “5-10 knots without stall warning activation.” The certification standard for the stall warning does play a role in the airspeed selection for the maneuver, and stall warning activation will vary from one airplane to the next, so it is important for the applicant to select an airspeed where the stall warning should not activate except on a momentary basis (e.g., due to turbulence).
The PTS standard for maneuvering during slow flight was for the applicant to establish and maintain “an airspeed at which any further increase in angle of attack, increase in load factor, or reduction in power, would result in an immediate stall.”
The current version of the Airplane Flying Handbook says slow flight should be performed at “the slowest airspeed at which the airplane is capable of maintaining controlled flight without indications of a stall—usually 3 to 5 knots above stalling speed.” The guidance has always intended for there not to be a stall warning, and that is consistent with slow flight guidance published in AC 120-111. However, the 3-5 knot range given does not pair well with the part 23 requirement for a stall warning (§23.207). It is not practical to maneuver in that airspeed range and not have the stall warning, which is an indication of a stall. The standard in the PTS also implies being right above the critical AOA, which means the stall warning would be activated. This result does not align with the guidance, or with what the FAA advocates. Specifically, the FAA does not advocate intentional disregard for a stall warning while maneuvering.
The purpose of teaching slow flight is to ensure that the pilot understands how the airplane responds with less airflow over the flight control surfaces. Since airplanes are operated at low airspeeds and high angles of attack during the takeoff/departure and approach/landing phases of flight, it is essential for pilots to learn the airplane cues and how to operate the airplane in this state. Regardless of airplane type, a pilot does not need to be just below the critical AOA to experience the desired characteristics and achieve the slow flight objectives. These objectives can be accomplished without deliberately activing the stall warning through flight just below the critical AOA. We want to influence the behavior and practices the pilot will follow outside the training environment. Therefore, with the exception of performing a full stall maneuver, a pilot should always perform the stall recovery procedure when the stall warning is activated.
With respect to guidance, the change to AC 61-67 published just prior to the final decision on the AFH wording change, which drove the FAA’s decision to modify this ACS Task element. We are working on another change to ensure the AC will align with the AFH and the ACS and be consistent with AC 120-111. To further explain these changes, we intend to publish a SAFO that is now in formal coordination.
Teaching what an airplane will do at the critical AOA is part of stall training and should be addressed in that context. You allow someone to ‘ignore’ the warning in one narrow instance – as part of stall training. The pilot can still learn what happens at that point – but as part of stall training and learning the proper recoveries – not as part of slow flight.
| improve this answer | |
