11
I was listening to liveATC today... Controller clears this guy into the class B for a transition and throws him a code. Some time passes and the pilot has now transitioned the bravo and is leaving the airspace. The conversation goes roughly like this:
ATC: N12345 are you going to want a handoff?
N12345: No sir but we'd like to hold our code
ATC: Okay, N12345 you are leaving my airspace, radar services terminated, squawk VFR, frequency change approved, see ya!
Now, I guess this boils down to two questions: 1) Why would he want to keep his code if he's not being handed off to another controller? What difference does that make? 2) Why did the controller still say to squawk vfr, even if the pilot wanted to keep his code and the controller said that's fine? Didn't the pilot go against an atc order by keeping his code and not squawking 1200?
I'm a sport pilot and have yet to use flight following (nor do I have my class B endorsement), so maybe I'm just missing something due to lack of exposure!
11
The pilot means: I'll be back again, so please don't assign this code to someone else.
Less workload for a pilot going in and out of class-B airspaces, and less hassle for the controllers, so they don't keep assigning a different code to the same plane.
The pilot will switch to the VFR code (1200 in the USA), and then use the one he's written down and used earlier for future passes.
  • $\begingroup$ Well, the pilot still has to switch to 1200 and then back, no? And most transponders don't have standby code, so they still have to dial it back, right? $\endgroup$
    Jul 1, 2016 at 13:23
  • $\begingroup$ What is the VFR squawk for non-USA? $\endgroup$
    – wallyk
    Nov 19, 2016 at 17:58
    $\begingroup$ @JanHudec Some transponders do have a standby code (usually you can toggle back and forth by hitting the "VFR" button). $\endgroup$ Dec 22, 2021 at 21:21
Without knowing more of the context it sounds like the pilot wanted to keep the code for flight following services, but the controller was unable or unwilling to provide them and instructed the pilot to sqauwk VFR (1200).
Keeping a code for future use is generally a no-no as discrete codes are limited in number to each facility and managed nationally. This is due to the octal 4096 transponder having so few available codes. There is actually a National Beacon Code Allocation Plan to divvy up the codes and prevent overlap between facilities:
https://www.faa.gov/regulations_policies/orders_notices/index.cfm/go/document.information/documentID/1027926
    $\begingroup$ The question says the exact opposite: ATC offered a handoff but the pilot declined it. Why he wanted to keep the code in that case is not clear, but returning soon seems like a reasonable guess. $\endgroup$
    – StephenS
    Jan 17, 2019 at 19:30
