Where would I find the document to use the temperature Gun on the ATR 42/72 conditioner pack. I have a #1 pack unserviceable. the flight compartment is hot. I want to map a temperature chart of the air-condition system
3$\begingroup$ Unfortunately this question is far too focused to probably get an answer here. If you are an A&P I'm sure you can talk to a manufacturer rep to get the information you need, but I really doubt that you're going to find another ATR mechanic here. Usually a "where can I find XXX" question isn't a good fit on this site, but I do hope you find what you need, good luck! $\endgroup$ – Ron Beyer Jun 27 '16 at 3:39
3$\begingroup$ I don't see why the unlikelihood of receiving an answer should warrant the question's closure $\endgroup$ – Federico♦ Jun 27 '16 at 6:57
1$\begingroup$ @Federico More specifically I'm trying to point out What topics can I ask here, where it says "Resource Location" is off-topic. $\endgroup$ – Ron Beyer Jun 27 '16 at 14:10
1$\begingroup$ @RonBeyer on that I can agree, the problem is that conflating the two points in a single post can get confusing, especially to newcomers. $\endgroup$ – Federico♦ Jun 27 '16 at 14:15
Add a comment
