I know you use the rudder when banking to keep the plane in the correct orientation, but is it possible, when making a slight turn with say a small private cessna, could you just use the rudder to turn?
    $\begingroup$ You can point the nose with it, but not turn as in a sustained turn rate. At very slow speeds, rudder input also rolls the plane (bank). But that's a different thing, if that happens, speed up. $\endgroup$ – ymb1 Jun 26 '16 at 22:35
  • $\begingroup$ @ymb1, if you apply rudder and keep the ailerons neutral, the most planes will roll into the turn and will do that at any speed. It is by design. $\endgroup$ – Jan Hudec Jun 27 '16 at 7:30
Yes it is possible to turn without ailerons. It is not recommended though. I have tried it on Cessna 172 as practice many times. I started practicing this maneuver some years ago after I witnessed a disabled Cessna with its ailerons jammed at an angle keeping it in perpetual turn was safely flown back to Van Nuys airport by an experienced instructor on the right seat. when you apply say left rudder the plane will bank left and turn left but you have to control the turn rate by power and rudder. The rate at which one applies the rudder is important; also you should be aware and anticipate potential risk of rolling. Again it is not recommended but in case of emergency it could save the day!
  • $\begingroup$ Note that on A320 if you lose all flight computers (extremely unlikely, of course), you are left with just horizontal stabilizer and rudder control and the aircraft was demonstrated controllable with that. $\endgroup$ – Jan Hudec Jun 27 '16 at 7:33
    $\begingroup$ And NASA also tested methods to control an aircraft with thrust only. Control with thrust was used both successfully (DHL Baghdad 2003) and not (UA 232 -- This story was depicted in a Mayday episode). $\endgroup$ – mins Jun 27 '16 at 18:21
