My professor usually asks us in our exams to plot the Thrust-Pressure ratio and TSFC - Pressure Ratio charts and justify the tendencies observed.
(TSFC = Thrust Specific Fuel Consumption).
We all know that, as the compressor pressure ratio ($\pi_c$) increases, the higher the Thrust ($F$) and the lower the $TSFC$. Here is a graph (which was taken from the book Fundamentals of Jet Propulsion with Applications, by Ronald D. Flack).
This chart was made after taking the final expressions for $F$ and the $TSFC$ (which are huge) and plotting them against $\pi_c$ using a computer. Obviously we don't have computers in the exam, nor we have enough time to derive such complex formulas. Here is an example for the (non-dimensionalized) $TSFC$:
Instead, I want to impress him with a convincing, non-mathematical, qualitative explanation of this behaviour.
Therefore my question reduces to: why, physically speaking, does the thrust increase with $\pi_c$? (The answer to "why does the TSFC decrease with $\pi_c$ can be answered saying that $F$ and $TSFC$ behave inversely to one another).
This is my attempt: As the compressor pressure ratio increases, the flow will be mixed and burned more efficiently in the combustion chamber, therefore increasing the energy available for the nozzle to accelerate the flow. Since the jet thrust increases with the exhaust speed, we can rest assured that a higher pressure ratio will translate into a higher thrust. The $(TSFC-\pi_c)$ behaviour will be inversely proportional to $(F-\pi_c)$, since $TSFC=\dot{m}_f/F$
NOTE: My explanation of the process, I think is a bit incomplete. For example, it doesn't explain why there is a $\pi_c$ for which $F$ will actually start decreasing (in the graph, this $\pi_c$ value is around 15).
