Raymer says:
Landing is much like taking off, only backwards!....Note that the aircraft weight for landing analysis is specified in the design requirements, and ranges from the takeoff value to about 85% of takeoff weight. Landing weight is not the end-of-mission weight, because this would require dumping large amounts of fuel to land immediately after takeoff in the event of an emergency.
What is the meaning of the last sentence: "Landing weight is not the end-of-mission weight, because this would require dumping large amounts of fuel to land immediately after takeoff in the event of an emergency"?
How is the aircraft design is affected by such different needed kind of weight?
(Source: Raymer: Aircraft Design – A Conceptual Approach Chapter "17 PERFORMANCE AND FLIGHT MECHANICS" Paragraph “17.9 LANDING ANALYSIS ”)
