As you might gather from Can planes benefit from Mitsubishi's Air Lubrication System? I'm interested in what possibilities there are for radically different approaches to aircraft body surfaces.
Aircraft body surfaces appear to be as smooth as possible, but not all things that fly well are smooth:
Has scientific or industry research indicated useful possibilities in new surfaces for aircraft body skins - or maybe alternatives to skins altogether?
    $\begingroup$ You can find a lot of what you want here $\endgroup$ Jun 10, 2016 at 23:05
    $\begingroup$ Possible duplicate of Is a golf ball surface a good idea for wings or fuselage? $\endgroup$ Jun 11, 2016 at 11:33
    $\begingroup$ @SMSvonderTann: This link is explicitly mentioned in the question. $\endgroup$
    – mins
    Jun 11, 2016 at 12:52
    $\begingroup$ @SMSvonderTann That's listed as a possibility, but not as the only one. This questions covers more ground than that one. $\endgroup$
    – Jae Carr
    Jun 11, 2016 at 13:29
  • $\begingroup$ I think boundary layer suction might form the basis of a good answer - several experiments have been done in the past. (Leaving this as a comment as I can't find the references.) $\endgroup$
    – Andy
    Jun 13, 2016 at 8:38
Non-smooth surfaces are already used, particularly in some Military Aircraft. If you've ever run your hand down the fuselage of an FA-18 Hornet you will find the surface is quite rough, much like the skin of a shark. At lower speeds very little is achieved, however at higher speeds small bubbles of air buildup in the indentations of the skin thereby creating an extremely slippery surface.
Take a look
Take a look here too
I'm certain my terminology is not correct, sorry about that. I would have put this all into comment, but I'm not allowed yet.
  • $\begingroup$ would you happen to have some references to back up your claims? $\endgroup$
    – Federico
    Jun 13, 2016 at 12:21
  • $\begingroup$ Sadly I don't know what the technology is called. However, a few years back I was lucky enough to get on-board an F18 and commented on the roughness of the skin. The squadron leader told me it was similar to shark skin and developed, at speed, extremely good aerodynamics as a result. $\endgroup$ Jun 13, 2016 at 12:35
    $\begingroup$ I did find this: flightglobal.com/news/articles/… $\endgroup$ Jun 13, 2016 at 12:43
    $\begingroup$ And this physics.aps.org/story/v17/st6 $\endgroup$ Jun 13, 2016 at 12:54
    $\begingroup$ This is exactly the kind of information I was after, would love to see it written up into a full answer. $\endgroup$ Jun 13, 2016 at 13:30
