On a recent flight, I was able to observe visual artefacts over the wing (Boeing 767-300 in cruise).
You can see them in the image below; they look like creases in a surface. They moved forwards and backwards over the wing. Later in the flight they extended to the end of the wing; at this point, they extended no further than a few metres.
I've added red and yellow arrows pointing to their ends - as you can see, one of them appears to fork.
Visual artefacts caused by shockwave over wing
Adjusting brightness and contrast makes the artefacts more visible:
Same image with increased contrast
I understand that this artefact is caused by a shockwave produced by supersonic airflow over the forward part of the wing.
I'd be interested to know: what exactly is it that I am seeing?
  • Is the artefact projected onto the surface of the wing, like a shadow?
  • Is the artefact a refractive distortion caused by different air densities?
  • In this image, there appear to be two creases, one behind the other - what do they represent?
  • What does the fork at the right-hand end of one of the 'creases' represent?
  • What do the darker and lighter portions of the 'creases' represent?
    $\begingroup$ You see a mirage, that is an image deformed by the change of refractive index, due to the huge change in air pressure / temperature / density. See shadowgraph. As the index changes, the phase of the light is altered, creating interferometric shadows. You can compare this with the effect visible over a hot road surface. $\endgroup$
    – mins
    Commented Jun 6, 2016 at 5:59
    $\begingroup$ I'm not sure this question is about aviation, also given @mins' comment above. $\endgroup$
    – Federico
    Commented Jun 6, 2016 at 6:33
  • $\begingroup$ Related (not a duplicate): Is the visual artifact seen over the wing from different air densities, a reflection or something else? $\endgroup$
    – mins
    Commented Jun 6, 2016 at 7:06
    $\begingroup$ This phenomenon is actually often used to visualize shocks in wind tunnels and experiments, see Schlieren photography And since we have an 'aerodynamics' tag, I don't think this is off-topic. $\endgroup$
    – ROIMaison
    Commented Jun 6, 2016 at 7:39
    $\begingroup$ The wing is illuminated 1/ By the scattered ambient light; 2/ By the ambient light altered when crossing the shockwave refractive volume: Refraction creates a shadow more or less visible by diverting a part of the light elsewhere; 3/ The direct light from the Sun (if any) which creates another (stronger) shadow. Then you see this illuminated wing through the shockwave. The rays are again curved / folded by the index changes, so the portion of the wing may not match exactly the surrounding details (that's not visible on the image)... $\endgroup$
    – mins
    Commented Jun 6, 2016 at 17:23
What you see are changes in the refractive index of the air, caused by the different pressure and temperature at different places. Sometimes, with the right conditions, there may be zones of transient condensation of water vapor, that add to the effect...
    $\begingroup$ In this video, the shock wave produced by a big explosion is clearly recorded by high-speed cameras... wimp.com/invisible-worlds-explosion $\endgroup$
    – xxavier
    Commented Apr 1, 2017 at 13:00
