Consider a large ATC facility, where a range of ATC services are provided and each position requires a dedicated person to manage (unlike small airports, where the same guy is ground + tower). Which positions are considered the most demanding, and it would make sense to assign a senior and experienced controller there?
I would imagine, Clearance Delivery is probably the easiest one, then Enroute, Approach / Departure, Ground and finally Tower. What's the training sequence recommended by the authorities for a new controller? After all, assigning a fresh trainee to LAX tower or JFK ground does not sound like a good idea.
closed as primarily opinion-based by falstro, RaajTram, Federico, SMS von der Tann, Ralph J Jun 4 '16 at 23:33
Many good questions generate some degree of opinion based on expert experience, but answers to this question will tend to be almost entirely based on opinions, rather than facts, references, or specific expertise. If this question can be reworded to fit the rules in the help center, please edit the question.
  • $\begingroup$ I'm guessing you can find lazy approach control sectors somewhere in the world, just as you can burn yourself out doing clearance delivery at Heathrow in a matter of minutes. $\endgroup$ – falstro Jun 4 '16 at 19:57
  • $\begingroup$ As worded, this question is essentially asking for opinions. I think you could ask the question without appealing to opinion, though I'm not sure it could be answered objectively. I'm not ready to vote to close, but do think the question needs a rework. $\endgroup$ – J Walters Jun 4 '16 at 22:20
  • $\begingroup$ Possible dupe and onother possible dupe $\endgroup$ – TomMcW Jun 4 '16 at 23:55
