The HondaJet has over wing mounted engines as can be seen here:
Image from LuxuryLaunches.com
The advantages v drawbacks of the over wing mount have been discussed here and here. The over wing mount on the HondaJet could take advantage of the Coandă effect, except that they're not in front of the wing, as can be seen (above), but more clearly here:
Sourced from HondaJet.com themselves.
In fact, the placement looks like the typical rear fuselage mount, except they're not mounted to the fuselage. The rear fuselage mount is quite common in the small private/luxury jet market:
Gulfstream G550 hosted by Gulfstream
Learjet 45 image from Aviation-Times.aero
This seems to combine all the disadvantages of an over wing mount with the disadvantages of a rear fuselage mount, and neither of those positions seem to have a huge amount of advantages.
What are the advantages of a high, over/behind wing engine mounting position as seen in the HondaJet?
4 Answers 4
Probably the reasons are similiar to the reasons which lead to the same mounting on the VFW-Fokker 614.
This arrangement was used to avoid the structural weight penalties of rear mounted engines and the potential ingestion problems of engines mounted under the wings. This allowed a short and sturdy undercarriage, specially suited for operations from poorly prepared runways.
// Update
The space in the cabin should be the actual reason in this case.
“I had the idea around 1996,” says Fujino. “The cost of a business jet is very high. To reduce the cost, you have to reduce the size of the aircraft, but then you sacrifice comfort. I wanted to make the aircraft smaller, but not sacrifice the cabin.” Most business jets have the engines mounted on the rear fuselage, and moving the structure and systems to support the engines out of the fuselage would maximise space inside the cabin without increasing the size of the aircraft, he believed.
As always, there are pro and cons:
The problem with an overwing engine is that interference between the nacelle and wing can accelerate the airflow and cause a strong shockwave, reducing the drag rise Mach number – the airspeed at which shockwaves form and drag begins to rise rapidly. Fujino says computational analysis and windtunnel testing enabled Honda to find a “sweet spot”, an overwing engine location that minimises the shockwave. The result, he says, is a 5% better lift-to- drag ratio – aerodynamic efficiency – in the cruise than a rear-engined aircraft.
  • $\begingroup$ Peter Kämpf's answer specifically mentions the 614, but, the engines don't seem to be nearly as far behind the wings as they do on the HondaJet. The reasoning of that point, though, seems valid. However, the second part of your answer seems to nail it. $\endgroup$
    – FreeMan
    Commented Jun 3, 2016 at 14:48
Another advantage: With the engines on the wing instead of being mounted directly to the fuselage, not as much noise and vibration is transmitted to the interior of the cabin.
Mounting them above rather than below the wings allows for a much shorter landing gear. That's important to small business jets, where the passengers typically board from a general aviation area, using the aircraft's stairs built into the cabin door, rather than the enclosed ramp that commercial airliners use.
Closer to the ground, easier to get into.
Imagine getting into a 747 or A380 by climbing stairs out in the open, and you can visualize why shorter stairs are desirable.
I think HondaJet engine is a compromise of trying to squeeze two jets on a small aircraft. Putting engine under the wing means that the aircraft becomes too tall.A business jet can't be so high that it requires external ladders/stairs for entry - that would preclude landing at many small airports. If you look at Embraer Phenom or Cessna Citation, they both put engine on the tail. The doors on both open downwards and have built in stairs. You could think of putting the Jets close to the fuselage - similar to a turboprop - but then the problem is that unlike a propellor plane the exhaust is too hot. Then you can think of putting the engines on the tail (like every other competitor). That is a reasonable arrangement, but for stability reasons you want to have most of your weight ahead of the mid-point. That way if you are overloaded (or if your engine fails) the nose points down. With all the weight at the back, in case of emergencies the engine ends up pointing up. Not the safest arrangement. There is also the problem of getting all the fuel from the wing to the tail. So Honda found yet another arrangement by putting the engine on a couple of stilts. This is OK, but still has the problem that if an engine fails the nose ends up pointing up instead of down. I bet they are thinking that the Honda Engine never fails.
    $\begingroup$ Welcome to aviation.SE! Answers that can site facts, preferably with sources, tend to be received much better here than answers which are "I think..." opinions. $\endgroup$
    – Ralph J
    Commented Jul 10, 2016 at 12:36
  • $\begingroup$ Honda may think their engines never fail, but every regulatory agency in the world will require that they prove the plane can continue a takeoff run and maintain controlled flight with one engine shut down. $\endgroup$
    – FreeMan
    Commented Mar 27, 2017 at 13:54
-2
One major advantage of the engine mount on the wing as opposed to the empanada One major advantage to the engine mount on the wing as opposed to the Tailcone of the aircraft was mentioned in an air and space article written by Bill Sweetman, when called How The 747 Got Its Hump. In the article, he talks about mounting an engine on the wing of an aircraft indirectly reduces the bending moment on the spars and in the wingbox during flight due to the weight of the engines helping to counteract the bending moment generated by lift in the structural components. As such there's a weight saving since these parts can be made thinner but still be able to take the loads needed.
  • $\begingroup$ The reduction in bending moment is also addressed in point 2.2 of Radu094's answer to the question I referenced in the 2nd here link in my original question. Your answer also doesn't address the specifics of mounting the engine above the wing as opposed to below it, which was my specific question. $\endgroup$
    – FreeMan
    Commented Jul 11, 2016 at 11:37
    $\begingroup$ Did you write this while hungry? $\endgroup$ Commented Apr 19, 2019 at 4:04
