11
When commercial airlines calculate the mass and distribution of passenger load, in the cases where they do not weigh the passengers directly, they use standard weight measures which have been approved by the appropriate aviation authority.
The standard weights can be broken down by passenger type (adult/child), by sex (male/female) and by other factors such as season or business/economy class. To obtain these figures a survey is carried out at an airport and appropriate measures are taken to ensure the sample is representative.
The result is a single value that represents the standard weight for a male/female/child/etc. Whilst the standard weight may have a minimal bias (i.e. a small deviation from the population mean), it does not represent the variance of the observed passenger weights. That is if the sample mean is 90kg with a std deviation of 10, the there is a ~15% chance that a passenger has a weight more than 100kg (assuming normal distribution, for the purpose of this example).
Given that airline operators have to be extremely careful and conservative with their weight management how do they account for this uncertainty in their calculations? Using the example above, if there were a flight with 100 passengers each >100kg, there would be an underestimation of mass by over 1 tonne (relatively small in comparison to total loaded aircraft mass, but still a large figure in itself).
Are accommodations for this variation incorporated into the standard passenger weight (say use mean + x std. dev.) or does this get included in the operational limits that the airline set for their max weight allowances in their various forms, for example reduced Max Zero Fuel Weight (MZFW) or Max Take Off Weight (MTOW)?
Edit: This is a slightly different question to a similar one about how a commercial aircraft has its mass determined. The focus here is more specific in looking at how the standard passenger weights are calculated and what are the assumptions around using that data.
    $\begingroup$ Possible duplicate of How does a commercial airliner measure its weight/mass? $\endgroup$
    – fooot
    May 31, 2016 at 20:05
    $\begingroup$ That answer doesn't directly answer the question, as it mentions that standard weights are used, however there is an informative link which details the process for determining standard weights through survey (aircraft-support.blogspot.co.uk/2009/09/…). Checking through this link it details how many samples are required to get an unbiased sample (by using the std. dev. in the calculation), but does not address how the variation in passenger weight is incorporated into the weight and balance calculations. $\endgroup$ May 31, 2016 at 20:13
    $\begingroup$ Well, for one it would be statistically very unlikely for 100% of the passengers to be above 100kg in your example. A "normal" variance will have some above and some below, which tend to average out, but that expected variance has to be taken in to consideration in the airline procedures. $\endgroup$
    – Lnafziger
    May 31, 2016 at 20:20
  • $\begingroup$ A couple of observations. (2) When trucking sports teams around, an airline will use a different average weight than on a normal runs. (2) A 737 has a useful load of around 75,000 lbs. and carries about 140 passengers. That's over 500lbs of useful load per passenger. The passenger weight is not going to be critical in a large jet. $\endgroup$ Jun 4, 2016 at 2:18
  • $\begingroup$ What about operating from countries where corruption is bad? Yesterday flew klm and had an extra piece of luggage. Got offered to pay a lower rate as long as it got in the pocket of ground handling staff. Apparently the guy told me it's a standard practice... I don't think this will be registered in official paperwork. Even though I did refuse to accept it.. $\endgroup$ Jun 4, 2016 at 18:48
They don't handle that uncertainty.
Safety is always the prominent factor in the aviation industry. That said, measurements need only to be "accurate enough" for the purpose of safety. Being off by small amount would not compromise safety.
Furthermore, the atmospheric condition is always different; it is so dynamic and cannot be precisely measured. As long as the measurement is accurate enough, the aircraft will fly.
Theoretically, you could argue that there's a chance:
  • calculated weight is already at MTOW
  • every passenger happens to weight way above average
  • they all bought a lot of souvenir at the airport shops
  • density altitude was extraordinary high
  • a 10 knots tailwind was present at takeoff
and the aircraft overrun the runway during its takeoff roll. However, such a chance is so small that we accept our current method as it is and expect the aircraft to tolerate that uncertainly within its designed safety factors.
Such believe was found to be wrong when a small aircraft crashed on takeoff in 2003. Regulations were then modified so that on a small enough aircraft, the actual weight of each passenger (plus luggage) must be used, rather than using a standard weight for estimation.
    $\begingroup$ Air Midwest 5841 crashed due to a combination of a) being overloaded and out of balance and b) having had its elevator cable turnbuckles improperly set during its most recent maintenance visit, leaving the pilots with insufficient longitudinal control. Neither would have been fatal on its own - the plane being overloaded and out of balance was necessary for that crash to happen, but not, on its own, sufficient. $\endgroup$
    – Vikki
    Apr 29, 2018 at 20:04
Not only does the FAA define standard passenger weights they have a lengthy AC describing how you should calculate loading. You can find that AC here.
4. What should an operator consider while reading this AC?
a. Accurately calculating an aircraft’s weight and CG before flight is essential to comply with the certification limits established for the aircraft. These limits include both weight and CG limits. By complying with these limits and operating under the procedures established by the manufacturer, an operator is able to meet the weight and balance requirements specified in the aircraft flight manual (AFM). Typically, an operator calculates takeoff weight by adding the operational empty weight (OEW) of the aircraft, the weight of the passenger, cargo payload, and the weight of fuel. The objective is to calculate the takeoff weight and CG of an aircraft as accurately as possible.
b. When using average weights for passengers and bags, the operator must be vigilant to ensure that the weight and balance control program reflects the reality of aircraft loading. The FAA will periodically review the guidance in this AC and update this AC if average weights of the traveling public should change or if regulatory requirements for carry-on bags or personal items should change. Ultimately, the operator is responsible for determining if the procedures described in this AC are appropriate for use in its type of operation.
You may be particularly interested in CHAPTER 2. METHODS TO DETERMINE THE WEIGHT OF PASSENGERS AND BAGS
The opening of the chapter pretty much covers that deviations may happen
200. What should an operator consider when choosing the appropriate method?
a. For many years, operators of transport category aircraft have used average weights for passengers and bags to calculate an aircraft’s weight and balance, in accordance with standards and recommended practices. This method eliminates many potential sources of error associated with accounting for a large number of relatively light weights. However, differences between the actual weight of passengers and bags and the average weight of passengers and bags can occur when using average weights.
b. Statistical probability dictates that the smaller the sample size (i.e., cabin size), the more the average of the sample will deviate from the average of the larger universe. Because of this, the use of standard average passenger weights in weight and balance programs for small and medium cabin aircraft should be examined in greater detail.
c. The next four sections describe four methods available to operators to determine passenger and bag weight. They are standard average weights in Section 2; average weights based on survey results in Section 3; segmented weights in Section 4; and actual weights in Section 5. An operator should review the following discussion and consult Table 2-1 to determine which method or methods are appropriate to its type of operation.
I will refrain from quoting the rest of the document but its worth a read on covers the topic well, it should answer the main body of this question.
Also of interest may be the FAA handbook on weight and balance.
From an operations stand point there are things to consider as well. First off airplanes have a CG range, not a single CG point. This range does in fact have some room to play with. The airlines only need to be within this range for TO/LD. Check out the FAA handbook for more on CG ranges. In theory the airline can (and does on occasion) move people around, although my understanding is that this happens more so in smaller commercial planes. When I fly the Archer or Warrior I typically fly you better believe all my passengers are stepping on a scale before the flight!
Some planes may have ways to mitigate this to an extent. Depending on airframes the fuel loading can be distributed differently among the tanks but you still must be with in limits for TO/LD of course. Any large plane that may also be carrying cargo (for shipping reasons not the baggage its self) may have some ability to rearrange the pallets to keep the CG within limits but this again depends on the situation.
-- EDIT (in response to CG range question in the comments below)--
As for how the planes are designed to handle this there is a CG range. This varies from plane to plane and some have bigger ranges than others. A full break down on how that works could be the subject of its own question here. Generally speaking there is a Max Takeoff weight that must fall with in a CG envelope. Here is the CG envelope for a Piper Warrior
enter image description here (source)
The charts for airliners have bigger numbers and some more boxes but its easier to describe the issue with a chart like this. As you can see at max gross weight you have 6 inches of CG play. While this may not seem like a lot its more than enough to play with when loading the plane. This leaves room to have passengers of different weights in different seats etc. For the sake of a complete answer it should be noted that these ranges are just the tested limits of the airframe if your CG falls out of these ranges the plane may still fly however it will exhibit different behaviors (high/lower cruise speed, easier entry to a stall or tougher exit etc.). There have been various accidents in history that happened as the result of a massive CG shift in flight, there is some debate as to the role that the over loading of AF4590 (the Concorde that crashed) played in the accident. You should be able to find similar CG range charts for most modern airliners out there if you want more specific ranges.
  • $\begingroup$ A very informative answer! I read through the links and this is what I have got from them: 1) there are various considerations that need to be taken into account in order to reduce the survey bias. 2) If the pilot believes there is a significant deviation, then certain measures should be applied - weighing the passengers, or use of pre-approved non-standard weights for certain passengers. However, there is no mention about handling the final uncertainty in total passenger weight, which makes me wonder whether if this is not significant enough to be of concern in practice? $\endgroup$ Jun 3, 2016 at 8:40
    $\begingroup$ I think its just statistically unlikely that the airplane ends up full of 200LB Summer Males all sitting in the rear, and a bunch of unattended minors in first class. It just not really feasible to weigh everyone, since the plane has a CG range it can have a mass range that moves around a bit as well. $\endgroup$
    – Dave
    Jun 3, 2016 at 13:50
  • $\begingroup$ A very low probability example to be sure. The tolerances of the ranges is what I am trying to figure out - how these CG or mass ranges are designed to account for this, or not as the case may be! $\endgroup$ Jun 4, 2016 at 16:19
  • $\begingroup$ The answer to that is long ill add it to the body of my response. $\endgroup$
    – Dave
    Jun 4, 2016 at 18:02
