11
Can small airplanes, such as a Cessna 172, dump fuel during flight?
My understanding is that large commercial passenger aircraft often have the capability to dump fuel during flight, as can many military aircraft. However, is that capability available for small 2 or 4 seat planes? How big does a plane need to be before a fuel dump capability becomes useful?
    $\begingroup$ A C-172 cannot dump fuel. As a guess, it's only useful for aircraft where the max landing weight is significantly lower than the max takeoff weight. $\endgroup$ May 17, 2016 at 20:47
  • $\begingroup$ The large really needs to be stressed here. Narrow-bodies like A320 or B737 either don't have that capability, or have it as option that most don't have installed. So why should anything smaller have it? $\endgroup$
    May 17, 2016 at 21:19
  • $\begingroup$ On a C172, the fuel weight is about 150 kg out of 1,200 kg. On a B747-8, the fuel weight is about 200 tons out of 450 tons. The benefit of dumping some fuel is not the same. Also fuel dumping must be done at relatively high altitude, so that fuel is evaporated before touching the ground. See What factors determine where an aircraft can dump fuel? $\endgroup$
    – mins
    May 18, 2016 at 7:01
  • $\begingroup$ I saw a question regarding a small plane crash where the poster wondered why the pilot didn't dump all his fuel on approach to avoid a fire. $\endgroup$ May 18, 2016 at 15:04
  • $\begingroup$ Fuel dumping becomes useful when the possible fuel load becomes a significant fraction of gross weight, like one third. It has less to do with size and more with fuel fraction and reduced landing weight. $\endgroup$ May 18, 2016 at 19:59
7 Answers 7
11
The short answer is, no, generally only large aircraft have purpose-built fuel dumping systems. Such a system may be helpful in reducing aircraft gross weight to a safe landing weight in the case of a precautionary landing. The approved landing weight of smaller aircraft, such as the C172, is generally the same as the approved takeoff weight.
The longer answer is, yes, it would be possible to "dump" fuel from an aircraft such as a C172, though not by means of a purpose built mechanism. The "dumping" would be more of a slow to moderately fast drain, depending on the means used.
If I wanted to drain the fuel from one of the wing tanks in a C172 while in flight I could use a pen, screw or other such device to drain fuel from the wing tank sump. A faster dumping/draining method—though requiring considerably more work—would be to unscrew and remove the fuel drain valve, thereby releasing all the fuel in the wing. Obviously, this later method would hamper the possibility of draining only a portion of the fuel from the wing tank.
I cannot think of any reason why I would want to drain the fuel in flight apart from reducing the risk of fire in the event of an emergency landing. And in that case, my prefered method of reducing the risk of a post-landing fire would be to concentrate my efforts on the landing, not on eliminating a fuel source.
Generally, I prefer to have more rather than less fuel in the tanks when I fly.
    $\begingroup$ Even 737s cannot dump fuel in-flight $\endgroup$
    – Ben
    May 17, 2016 at 22:47
  • $\begingroup$ In addition to your points, systems designed to dump fuel actually spray it to limit / prevent effects on the ground, so it would be in last resort and taking the possible effects into account. $\endgroup$
    – mins
    May 18, 2016 at 8:21
  • $\begingroup$ I wouldn't want to try that method either, you are likely to have fuel dripping down your arm and soaking your clothes, and filling the cockpit with nasty fumes. You'd be exposing yourself to tetra ethyl lead which is extremely toxic. $\endgroup$
    – GdD
    May 18, 2016 at 11:18
  • $\begingroup$ There is one theoretical reason for doing this: if air can't get into the fuel tanks because the wing vent is blocked then the fuel flow will stop at some point. You can let air in by opening a sump, which will restart the fuel flow temporarily; repeat until you can land. But it's a really unlikely scenario: there's an AD requiring vented fuel caps so it should never happen in the first place, and even if it does you would have to actually think about venting and have enough time to try the sump. I guess most pilots would just assume a blocked fuel line and concentrate on landing. $\endgroup$
    – Pondlife
    May 18, 2016 at 13:12
  • $\begingroup$ @GdD Not sure about the toxicity as compared to any other lead, but it wouldn't be a problem for anyone running on unleaded, which is common. $\endgroup$
    – J W
    May 18, 2016 at 13:43
As Jonathan mentions these systems are typically not found on light aircraft as there is little need for them but in some cases the design of the plane may allow for it. The Piper Saratoga has has an in cabin fuel drain switch that drains fuel from a center drain at a low point on the fuselage. This is intended for expelling water from the system but can in theory be used to dump fuel.
enter image description here (source)
Other aircraft may have similar systems as well. The small/older cherokees however do not contain such a system.
On some small aircraft it is possible to dump a small portion of fuel by mishandling the fuel system.
On certain models of Cessna 310, 401, 402, 414, 421 and similar aircraft, the auxiliary tanks feed return fuel back to the main tanks. Normal procedure is to burn down the mains before switching to the auxiliary tanks. If the mains are full the return fuel from the auxiliary tanks will overflow the mains and be vented overboard. Wing locker tanks were pumped directly into the mains and would also cause venting overboard if activated too early.
One time I was asked to take a Cessna 310 to a very short runway to pick up 5 passengers and their luggage. The aircraft had accidentally been fuelled to 1,200 lbs. when only only 600 lbs was needed to complete the trip. The extra 600 lbs. of fuel would have made the aircraft over weight
Shortly after take off I switched to the auxiliary tanks and also activated the wing locker tanks. This resulted in the main tanks becoming over filled and about 400 lbs of fuel was both consumed and also vented overboard during the 1 hour flight.
While this was not an actual example of fuel dumping, it had the same effect, and allowed me to depart a short runway with a full load of passengers and baggage while not being overweight.
    $\begingroup$ So, what you're saying is that it pays to know your plane? Also, wouldn't it have been more practical to off-load some fuel before takeoff instead of dumping it in flight? (Maybe he should ask a new question...) $\endgroup$
    – FreeMan
    May 18, 2016 at 12:31
  • $\begingroup$ Removing the fuel from the aircraft would have taken time, and since the fuel is then considered contaminated, it is usually disposed of. $\endgroup$ May 18, 2016 at 21:03
  • $\begingroup$ got it, thanks. $\endgroup$
    – FreeMan
    May 18, 2016 at 23:29
Usually no, although in some cases you may be able to dump fuel by exploiting features of the fuel system. Why not on smaller planes? Fuel jettisoning systems were only ever required for transport-category aircraft. There is some reasoning behind this link, since many transport category aircraft perform comparatively poorly at MTOW and would take a long time to burn off the difference between maximum take-off and maximum landing weights. Many GA aircraft can even land at their maximum take-off weights and so don't list a separate landing weight. (See, for example, the C172 POH)
The reason for this discrepancy between small and large aircraft, like many differences between transport category and GA aircraft, is in part due to practicality and in part due simply to regulation. Fuel jettisoning is required on many transport aircraft but is not required on GA aircraft. The FAA had a regulation that stated (though it's since changed to be performance, not weight-based):
Sec. 25.1001 Fuel jettisoning system.
(a) If the maximum takeoff weight is more than 105 percent of the maximum landing weight, there must be a fuel jettisoning system able to jettison enough fuel to bring the takeoff weight down to the maximum landing weight...
version of 25.1001 effective on 02/01/1965.
There is good reason for the distinction between small GA aircraft and large transport aircraft in certification requirements. First, many GA aircraft are designed to be able to land and take-off at the same weight. Other reasons include performance consideration and that fuel flow is not proportional to max fuel, in part because larger aircraft usually have longer ranges. Longer range means more distance to burn off all the fuel, which usually makes it harder to burn off any unwanted fuel.
If you want to be technical, the driving factors here are the performance at MTOW and the practicality of burning off the difference in MTOW (max takeoff weight) and max landing weight, not fuel fraction (fuel available/empty weight) and not necessarily the ratio of MTOW to max landing weight. As counterexamples to the notion that fuel fraction or MTOW/MLW are important, the F7x can hold almost 90% of its empty weight in fuel but can also land at almost 90% of its take-off weight and so has no fuel dumping. Even a Learjet 60XR, with a MTOW to MLW ratio worse than an A320, can burn off the difference in fuel during a little more than a 300 nm trip. By comparison, by my calculations a 757-200 could make a 2,000 nm trip without burning off the difference between maximum take-off and maximum landing weights, and circling for hours burning off fuel like that tends to horrify passengers. (Source: Plane Purchasing Handbook 2012 and this 757 presentation).
You may also want to read: Why doesn't the 737 have a fuel dump nozzle? and When are aircraft required to dump fuel for emergency landings?
The answer is simple.
If an aircraft's maximum takeoff weight is significantly greater than its maximum landing weight it needs to be able to dump fuel so that it can land quickly.
Small planes, such as C-172, can usually land at maximum takeoff weight. Thus they have no need for fuel dumping capability.There simply is no need for dumping fuel in a C-172 so the aircraft does not have that capability.
  • $\begingroup$ The 737 can have a difference between maximum takeoff weight and maximum landing weight of 30,000 lbs, but does not have fuel dumping capability. While your answer is correct for some cases, perhaps you could make it better at covering these corner cases where perfomance, not take-off and landing weights, is the driving factor. $\endgroup$
    – Cody P
    May 19, 2016 at 16:29
  • $\begingroup$ This question came from another question regarding a small plane crash where the OP wondered why the pilot didn't dump all his fuel on approach to avoid a fire. $\endgroup$ Jul 25, 2016 at 20:38
the Mooney M20M has a gross take-off weight of 3368, and a gross landing weight of 3200#.
Although not designed for fuel dumping, it has a operable valve on the floor of the right seat that is used for draining the lowest part of the fuel system, and this valve could be used to dump 168# or 28 gallons of fuel, although it would take a fairly long time.
The better technique is to do a soft-field landing at full gross on a long runway.
Generally, no. However in the Piper J-3 cub.. just fly upside down for a few minutes (you'll then be a glider unless you have an inverted fuel and oil system). Plenty of fuel will drain out around the metal wire which is your fuel gage. :)
