15
(Assuming no collision.)
I wonder about sonic boom existence and effects when two fast aircraft interact, for example:
  • When supersonic aircraft flying opposite routes cross each other, do pilots hear a sonic boom?
  • If they fly in the same direction, with the appropriate offset, does one hear a permanent sonic boom?
  • If two aircraft fly in opposite directions at Mach 0.6, can they create a sonic boom by adding their individual shockwave speeds?
Further than the sound aspect:
  • What are the effects on the aircraft?
  • Is there a distance after which the effects become insignificant?
If the aircraft are near enough, yes.
The boom will not be permanent i.e. static, but yes, it will be persistent. However, it should be noted that the shocks from various parts of the aircraft body will interact nonlinearly (mostly coalsce), resulting in unpredictable results.
No, sonic boom is caused by the object travelling faster than sound while the disturbances travel in the medium with speed of sound and get 'bunched up'. So, the aircraft has to fly supersonic with respect to the medium
Shock wave is basically a pressure discontinuity. So the effect will be similar to that of an impact, whose strength depends on the shock wave.
Yes, but it depends on the aircraft size and the speed. The shock wave produced by the bullet loses its strength in a short distance, while the Concorde has to be flown over sea and Tu-144 at over 35000' to mitigate the effects.
  • $\begingroup$ In the first part of your answer where the a/c are in opp directions it seems to me neither pilot would hear the other. The sonic boom, and all other sound of the a/c follows it. The boom propagates at the SOS, so if the other a/c is going faster it would not catch up to him. $\endgroup$ – TomMcW Jun 13 '16 at 19:31
