In military aviation, crews will sometimes refer to "angels" meaning MSL altitude. However, one might guess that it is a pronunciation of AGL (AnGeL), above ground level. Did it originally mean AGL and then at some point it changed meaning to MSL?
    $\begingroup$ It's never meant above ground. For one thing a pilot doesn't always know how far above ground they are as that changes all the time. AGL is useless information to broadcast as it doesn't give a common form of reference. I can't tell if I'm at risk of collision if someone says they are 10000ft agl. $\endgroup$
    – GdD
    May 16, 2016 at 13:14
  • $\begingroup$ I highly doubt that the abbreviation "AGL" was in widespread use at the time the "angels" term first started being used. $\endgroup$ Jul 9, 2019 at 17:37
5 Answers 5
20
It was originally Royal Air Force slang for altitude in thousands and not a way of pronouncing AGL.
Up in the air, where the angels fly.
https://en.wikipedia.org/wiki/RAF_slang
Angels 10 meant 10,000 feet. Cherubs were hundreds of feet.
    $\begingroup$ The question is still unanswered: Was "Angels" always MSL or was it once AGL? $\endgroup$ May 15, 2016 at 16:41
  • $\begingroup$ @MikeSowsun I'm not sure. I've looked for references, but I doubt there are any easy to find ones. I believe that regional QNH was used. I doubt that the difference in AGL and MSL would be very important anyway since the accuracy of the RADARs or spotters used would not be less than the difference. $\endgroup$
    – Simon
    May 15, 2016 at 16:54
  • 15
    $\begingroup$ My main point is that angels was not some way of pronouncing AGL. $\endgroup$
    – Simon
    May 15, 2016 at 16:57
  • $\begingroup$ I agree, it probably had nothing to do with AGL and was always MSL. $\endgroup$ May 15, 2016 at 17:11
    $\begingroup$ @DanHulme Hi Dan. Do you have a reference for this? I've been trying to find some. $\endgroup$
    – Simon
    May 16, 2016 at 10:17
No, it always meant altitude and altitude means above mean sea level since it is distinguished:
  • Back in 1930s and 1940s when the term was already in use, there was no way to find height above ground level at all. Even now the radar altimeters only measure height up to few thousand feet.
  • The term is mainly used to describe position of flights over the battle area, for which you need something that will immediately tell you whether the other flight is above or below you. Altitude is such thing—higher number means above, lower number means below. Height wouldn't work as a flight over mountains can have lower height AGL and still be above you.
    $\begingroup$ QFE and QNH were (and still are) used to measure height with pressure altimeters. QFE gave height above ground. "Angels" was not measured by aircraft, it was the reported height of attacking aircraft given by the "chain home" RADAR stations or ground observers. $\endgroup$
    – Simon
    May 15, 2016 at 17:41
  • $\begingroup$ @Simon, well, QFE gives height above airport (field elevation), which is different thing from height AGL. QNH, of course, gives altitude. Thousands of feet is low enough precision that the difference between QNH and QNE does not really matter. $\endgroup$
    May 15, 2016 at 20:55
  • $\begingroup$ It was my understanding that all a radar altimeter can tell you is when you are about to crash or land. $\endgroup$ May 16, 2016 at 8:27
  • $\begingroup$ @HowardMiller, not exactly. Radar altimeter measures height above ground, accurately to few feet, but only up to few thousand feet. The thing that tells you when you are about to crash or land is (E)GPWS, which uses the radar altimeter output, but in the newer versions also GPS altitude and position and a map so it can tell you when there is a rising ground ahead of you—the radar altimeter only measures directly down. But all these things are much newer than the term “angels” anyway. $\endgroup$
    May 16, 2016 at 8:35
  • $\begingroup$ "Angels" is probably still around because it sounds cool in movie dialog. Like "Breaking atmo". $\endgroup$ May 16, 2016 at 16:52
Close to the ground, altitude AGL matters far more than altitude MSL, since it is the ground that you're trying to land on, or avoid running into. At higher altitudes, however, altitude AGL matters far less, and is much harder to determine, and thus altitude MSL is used as the reference. That is also what is read on the barometric altimeter.
Thus, for an aircraft looking to join up with (or avoid hitting) another aircraft, giving the altitude in the same reference (MSL, not AGL) that can be readily read on the instruments is most useful.
Besides, if that aircraft is over a mountain and I'm over a valley, we might be at the same altitude even though he is at 4000' AGL (above the ground directly beneath him) while I'm at 6000' AGL (above the ground beneath me).
One might ask, why not set QFE and reference everything to the "ground level" at some particular airport, rather than referencing everything to sea level. You could do that, AS LONG AS everybody has the same QFE for the day. If you're doing all your flying in a theater where all the airfields are at about the same altitude, this probably wouldn't cause much problem, but if I have QFE set for the field I took off from (elevation 10' MSL), that setting won't show me what I want to see if I end up landing at another field at say 500' MSL!
Thus, the fairly common choice to set altimeters to read height above sea level, and thus reference calls of other aircraft altitude to that same standard.
"Angels" is flight level in thousands of feet based on the common barometric pressure of (I think) 1013.25mbars (29.92mmHg). Angels is not typically used when you have a QFE or QNH to reference and is usually used above a certain altitude only and when away from all other references. For example a transatlantic flight once over the ocean could use MSL, but in a transmission to other aircraft that are currently using QFE or QNH over land, this reading is not right for them to reference for anti collision. To that end, once you are in an air corridor with other aircraft, and I think usually above about 18,000ft, the altimeter is set to a common value of, like I said, I think, 1013.25mbars and then FL is used so all are on a common altitude reference.
-3
On another note AGL primarily stands for Aeronautical Ground Lighting as in runway/airfield lighting systems that pilots rely upon to safely land aircraft including PAPI lights.
  • $\begingroup$ No, that's not what AGL means in this context. VTD as not an answer to the stated question. $\endgroup$
    – Ralph J
    Aug 10, 2022 at 1:24
  • $\begingroup$ AGL is primarily used to denote Above Ground Level. In my many years at the FAA I never heard it used to reference lighting. $\endgroup$
    – RetiredATC
    Aug 13, 2022 at 20:21
