I am part of a team developing a Cessna 172 P model for FlightGear, an open source free flight simulator. We are now programming how the panel and radio lightning rheostat should work, but we found a lot of unclear and/or contradictory information about it online. Our main problem is to understand how the radio light knob (labelled as RADIO LT) work in these older models of the 172.
The POH from 1982 states the following:
The engine instrument cluster (if post lights are installed), radio equipment, and magnetic compass have integral lightning and operate independently of post or flood lightning. The intensity of this lightning is controlled by the inner knob on the light dimming rheostat labelled RADIO LT; rotate the knob clockwise to obtain the desired light intensity. However, for daylight operation, the compass and engine instrument lights may be turned off while still maintaining maximum light intensity for the digital readouts in the radio equipment. This is accomplished by rotating the RADIO LT knob full counterclockwise. Check that the flood lights/post lights are turned off for daylight operation by rotating the PANEL LT knob full counterclockwise.
This makes it look like the RADIO LT knob controls both the brightness of the radio digital readouts (i.e. the frequency digits) as well as other types of lights (radio cluster buttons and compass), but I found out that other renowned simulations of the 172 for other simulators do not dim the digital readouts with that knob. It also seems strange to me that one would be able to dim the radio digits under any condition, let alone turn them completely off.
So does anyone here have experience with these models of the 172? Would anyone be able to describe how to best model the behaviour of the radio lights?
