25
In the shock wave of the next image (in a blunt body)
Why the wavefront is in front of the object? It does not assume that if the object travels faster than the speed of sound wave front should be just touching the object that causes it ?
    $\begingroup$ @mins, edit of the comment? No. Well, the shock must be, always, ahead of the object. The shockwave touching the object would produce infinite pressure or some such physical impossibility. $\endgroup$
    May 9, 2016 at 11:28
    $\begingroup$ Is this not adequately explained in the Wikipedia article where you found the image? $\endgroup$ May 9, 2016 at 17:56
    $\begingroup$ The air between the shock and the body also travels at supersonic speed. For the outside flow it looks like part of the body. $\endgroup$ May 9, 2016 at 19:57
    $\begingroup$ "In other words, when the needed rotation of the fluid exceeds the maximum achievable rotation angle for an oblique attached shock, the shock detaches from the body." - Nope; still not in English. $\endgroup$
    – Mazura
    May 9, 2016 at 23:14
30
After passing through the shock wave, the air still has to evade the body. If the shock-wave touched the body, the air would have to escape through infinitely thin space at infinitely high pressure and it obviously can't do that.
So behind the shockwave there is a boundary layer (called shock layer) in which the air is moving with the body and flows, under high pressure, to the sides where it can escape.
The blunter the body, the thicker the boundary layer, because the air must cover longer distance to the sides and takes longer to do that.
Of course the high pressure between the shock and the body causes a lot of drag, which is why sharp nose and leading edges are preferred for supersonic flight.
  • $\begingroup$ Boundary layer sounds correct. A boundary layer is the layer between the bulk of a fluid (or gas) which isn't affected by a solid object and that object itself. $\endgroup$
    – MSalters
    May 9, 2016 at 15:49
  • $\begingroup$ @MSalters, I still think there was a more specific term for distinguishing this kind of layer behind shock wave from the boundary layer around object seen in subsonic flow, but it's been long I read about this and I don't remember where. $\endgroup$
    May 9, 2016 at 16:08
    $\begingroup$ Entropy layer / shock layer? $\endgroup$
    – costrom
    May 9, 2016 at 19:34
    $\begingroup$ @LightnessRacesinOrbit, this kind of shock is indeed called “bow shock”, but I meant the subsonic layer behind it, which is called “shock layer”. $\endgroup$
    May 9, 2016 at 19:42
    $\begingroup$ Fun fact: you can never really touch something, for basically the same infinite-force reasons. When you "touch" a desk, you're really just getting close enough that electromagnetism pushes the atoms in your hand and the atoms on the desk apart with a lot of force. When you stand on a rock, same thing. (You could probably say that you actually touch the ground if you're on a neutron star, but then you'd also be quite dead.) $\endgroup$
    – yshavit
    May 15, 2016 at 17:55
10
In case of an infinestimally thin body in supersonic flow, the disturbances created propogate as Mach waves. However, as the the thickness of the body increases, the flow has to physically turn away from the object after the shock wave.
For example, if a wedge at an angle $\theta$ is placed in supersonic flow, the fluid has to turn by that angle after passing through the compression shock (so that the flow is along the body).
For a given upstream Mach number $M_{1}$, there is a maximum turning angle $\theta_{max}$, beyond which an oblique shock is physically not possible and the shock wave gets detached i.e. it is physically not possible to turn the flow suddenly while conserving mass, momentum and energy. The flow 'solves' this problem by detaching the shock in front of the body.
Perhaps, at the root of your question, there is a misunderstanding of the nature of a shock wave. A shock wave is a surface, an ensemble of points, where the properties of the gas change discontinuously (it is not the only surface with this characteristic, but the other class, that of contact discontinuities is absolutely unstable, and quickly disappears).
Thus a shock wave has gas on both sides of it, by definition. Hence, it cannot touch the object, because there must be another layer of gas between the object and the shock wave.
But now your question can become: why must there be gas on both sides of the shock wave? The reason is that fluid must cross the shock wave, i.e. fluid goes continuously from the front to the back of the shock wave (discontinuous are the thermodynamic properties of the gas, and the component of the perpendicular speed across the shock wave, but otherwise gas move continuously from one side to the other).
Are there surfaces where matter does not cross a surface of discontinuity? Yes, there are, and they are called contact discontinuities, which, being absolutely unstable (the term absolutely has a very special meaning in fluidodynamics), quickly disappear.
The second part of your question,
seems to indicate that you are thinking of a shock wave as a regular wave, hence the blunt object should catch up with it. Unfortunately, calling a shock wave a wave is a historical relic, which betrays the fact that shock waves move supersonically with respect ot the fluid in which they propagate. In fact, there can be no shock wave which moves sonically or slower, lest the second principle of thermodynamics be violated (Landau and Lifshitz's Fluid Mechanics volume has a beautiful proof of this theorem, in full generality).
As a matter of fact, we (could) take the above statements (in a quantitive form, mind you) and push them one step further: since the motion of the post-shock gas is slow (i.e., subsonic) with respect to both the shock wave and the blunt object, its flow away from the fore of the blunt object occurs slowly, so that more and more fluid is trapped between the shock wave and the object. More fluid means more counter-pressure, hence the the shock must be located further and further from the blunt object: it forms close to the tip of the blunt object, but then it drifts away from it.
The truly cute feature of the picture above is the well-defined turbulent region in the object's wake...
EDIT:
As per mins' request (see below), you can see it as follows.
The speed of sound arises when you consider the fate of small perturbations. Imagine for instance that you locally compress matter a tiny little bit, i.e. you increase the density from $\rho$ to $\rho + \delta\!\rho$. In fluids, a higher density of a given fluid (= a smaller occupied volume) induces an extra pressure, so that, locally, $p\rightarrow p + \delta\!p$. So now you have a small volume whose pressure exceeds that of the surrounding medium: what happens? It obviously expands, i.e. pushes away nearby matter in order to claim for itself the volume occupied by the surrounding medium. Hence, a small increase in local density results in nearby matter having to move away, dislodged by the extra-density volume.
The dislodged matter moves slowly, because the force acting on it is small: we assumed that the extra pressure is small compared to the average pressure, $\delta\!p \ll p$. However, the first dislodged parcel of fluid sits next to another (for the moment static) parcel of fluid, which itself must make room for the first parcel of fluid, giving rise to a second dislodged parcel of fluid, and so on. There will be $N \gg 1$ dislodged generations of parcels of fluids, all set in motion by the original compressed fluid element, and reached eventually by this chain of dislodgings.
At first sight, one might think that this chain of dislodging events goes only as fast as each parcel of fluid, which is very slow as we said above, but this is not the case. The reason is that what we are asking is not the speed at which is parcel of fluid is moving (slow, as stated above), but how long it takes for the $N$-th generation dislodging to begin, not to complete. The speed of sound identifies the moment when the $N$-th generation dislodging begins, not ends, it identifies when the first perturbation arrives, not when it completes.
This speed is much larger than the speed at which individual parcels move. When we have compressed the initial parcel, we have also heated it (compression leads to heating, in normal materials), hence the average molecule will have a higher-than-before temperature $T+\delta\!T$. As you clearly know, a molecule coming from a warmer region is slightly faster (in the average) than one from a colder region because $v \approx \sqrt{kT/m}$, so that the first generation dislodged material will first notice that it has a warmer (=greater pressure) neighbor when it is first reached by its hotter-than-average molecules, which travel at speed $\approx \sqrt{kT/m}$. Thus the speed with which the message Slide over, you wimp travels is the same as that of the molecules from the warmer surroundings.
These hotter-than-average molecules from the hotter surrounding collide with the average local molecules, and transfer to them a bit of their extra energy, i.e. local molecules are heated by the collisions from the original place of compression. Now these newly heated molecules will move out to the region of the 2-nd generation dislodged gas, and repeat the process again: the speed with which the signal travels, i.e. the first perception that the local gas must start moving, is again (actually, always) that of the molecules, $\approx \sqrt{kT/m}$. Hence the sound of speed is $c_s \approx \sqrt{kT/m}$.
In the derivation above I have skipped some details, whose inclusion however only modifies $c_s$ to the extent of replacing the previous formula with $c_s = \sqrt{5 kT/2m}$. The real detail I left out is that, once compression occurs, in real fluids this does not necessarily lead to the maximum heating possible (which leads to the factor $5/2$ above), but it can be lower than that because some of the extra heat may be dissipated away before the warmer-than-their-surrounding molecules have managed to reach their surroundings. If heat is dissipated (via viscosity, radiation, whatever) then it takes longer for the first-generation fluid to realize that the initial parcel of fluid has been compressed, because fewer of the molecules arriving to it are warmer than its own molecules.
  • $\begingroup$ It would be perfect for my understanding if you could also revisit another relic: the definition of speed of sound: Is it the maximum speed an air molecule can travel by itself when pushed by its neighbors. If so why? Friction/viscosity? $\endgroup$
    – mins
    May 16, 2016 at 12:04
    $\begingroup$ @mins I have written a qualitative explanation of the speed of sound for the non-physicist in an Edit. I hope you find it satisfactory. $\endgroup$ May 16, 2016 at 13:14
