16
As far as static thrust, does a shrouded/ducted propeller outperform an un-shrouded propeller? It seems that the guide blades on the bottom of the duct would allow little more thrust to be extracted from the vortex the prop generates by redirecting the air flow. Also the duct seems like it could "focus" the propelled air (like a rocket thruster) resulting in better thrust.
(Source)
Of course I can see how an improperly implemented duct could really kill efficiency (creating more interference and turbulence), but what about a well designed one? And if they are better, why wouldn't we seem most propeller aircraft use them (what is the advantage about not having the duct)?
19
there is a lot going on here. Short answer is that a ducted fan (what you have pictured) can produce a lot more thrust (experiments from one paper say twice as much) than an open rotor of the same size. The big thing that these ducted fans have going for them is the fact that tip losses become negligible because there simply isn't room for the tip vortex to develop because there is a duct in the way! Simple, easy solution that works well.
However, nothing comes for free. One, you have to have the duct there, which is weight & money (you have to build the duct and the support structure, which adds some drag too). Think of scale too--as propellers get larger, the duct has to grow with them. Imagine the difficulties in putting a 20' duct on a B-36 propeller!
Second, the manufacturing tolerances on the duct are critical--the tighter it is, the more efficient you are (to a limit, naturally)...but the tighter it is, the more susceptible you are to having your blades strike the duct due to flexing of the duct or the blades. And, speaking of flexing blades and the necessary support structure you'd need, this could make pitch control (on a propeller, variable pitch, and on a rotor, cyclic and collective) difficult to implement, depending on which of those schemes you're looking to do. Then again, for a small implementation using RPM control...maybe you don't need those anyhow.
Similarly, while a crosswind on an open rotor leads to a sudden decrease in power, a crosswind on a ducted fan leads to a sudden pitching moment due to the lip of the duct and the asymmetric inflow to the fan (which, since you're now producing more thrust to begin with, asymmetric inflow effects become even more pronounced). Now, if you stick this on the front of a typical Cessna 172, say, and throw a crosswind at it (which, if you think of takeoffs and landings, which since they must be in a certain direction, having a crosswind is actually quite likely) imagine the yawing moments that would be induced by the propeller (proportional to the static thrust) -- even before the aircraft got off the ground and before you have a lot of control authority to counteract it! A similar scenario in the air could be as dramatic. And, yeah, you could throw some guide vanes at it to help, but nothing comes for free. Guide vanes, which is a workable solution, now mean that you need to have actuator(s) for those vanes, power & maybe hydraulics for the actuator(s), mounts for the actuators, hinges for the vanes, linkages from the actuator(s) to the vanes, redundancy for the actuation or some means of facilitating control in an emergency...it's a lot of work. Or, by contrast, you could just bolt a fixed pitch prop on a shaft at the front of said Cessna 172 and call it a day.
In the long run, and this is some speculation, I think it just leads to a more complex system, particularly in full-size implementations, which is a maintenance, cost, and manufacturing headache that isn't worth having if you can get plenty of performance from a regular open propeller. If you venture into the world of diffuser augmented wind turbines, there have been similar debates going on for decades...and a ducted wind turbine has yet to be successful on the large scale. Similarly, while ducted fan aircraft have flown...
Ryan XV-5A Vertifan, circa 1950 (Ryan XV-5A Vertifan, circa 1950. The ducted fans are underneath the circular domes on the wings and another under the shuttered area on the nose for pitch control. Source: http://www.aero-web.org/specs/ryan/xv-5a.htm)
...there aren't any non-MAV examples around today that I know of.
Source: https://theses.lib.vt.edu/theses/available/etd-05262005-170916/unrestricted/WGraf_Thesis_2005.pdf
  • $\begingroup$ Please source your image, as well. It's not clear if it comes from the thesis paper, or somewhere else. $\endgroup$
    – FreeMan
    May 9, 2016 at 14:17
  • $\begingroup$ Got it--thanks! $\endgroup$
    – Marius
    May 10, 2016 at 1:51
  • $\begingroup$ The Edgley Optica is a good example of a flying civilian ducted-fan aircraft. $\endgroup$
    – Dan Hulme
    May 10, 2016 at 9:34
  • $\begingroup$ So what do you think about adding only guide vanes without the duct? $\endgroup$ May 10, 2016 at 15:32
  • $\begingroup$ I'm not sure ducted fans were used in the XV-5A Vertifan. These are lift fans driven by gas from the engine (which is not on the wings) and using the circumference of the fan as a turbine. The duct is actually the turbine annular duct, I don't know if it is also used as a fan duct. $\endgroup$
    – mins
    Apr 28, 2017 at 17:50
A ducted fan can be designed to produce more thrust at the same fan (and same diameter) than a propeller -- or it can be designed to produce the same thrust at lower power.
However, it is not likely to be achieved with a very short duct like the one you have pictured. That is more of a shroud that merely protects people from the blade tips.
The longer you can make your duct, the more you will be able to take advantage of this aerodynamic phenomena. It also helps to have a nice rounded inlet to the duct -- often called a bellmouth. I would look for a duct length-to-diameter ratio of at least 0.5 for a reasonable augmentation.
Another thing to keep in mind is that ducted fans have much more than 2 blades. Increasing number of blades decreases the propeller/fan efficiency. The main advantage of increasing number of blades is to get higher thrust density, i.e., getting more thrust with the same propeller/fan diameter. So, what ducted fans really do is: the multi-bladed fan provide a lot of thrust density and the duct try to compensate the efficiency lost. Hopefully, the ducted fan can achieve the same efficiency of the 2-bladed propeller...
    $\begingroup$ Firstly, welcome to Aviation Stack Exchange @HenriqueMoritz. As for your answer, you definitely have a valid point with your explanation that increasing blade count generally improves many factors of efficiency, but nonducted and ducted fans can have similar to equal blade counts. The question in specifics is asking about the aerodynamic effects of the duct itself, which iirc offhand, mainly contributes in the area of thrust loss at the tips, which leads to issues that are countered by the ducts. Thrust density does improve with ducted propulsion though, so I see what you're saying here. $\endgroup$
    – Jihyun
    Dec 25, 2018 at 17:12
