For large drones like the Reaper, X-47, and aircraft like that, how do the "pilots" communicate with ATC when they need to?
2$\begingroup$ they don't the guy flying it does $\endgroup$ – ratchet freak May 6 '16 at 21:48
5$\begingroup$ @ratchetfreak: By phone using only ground channels from pilot location to ATC? Or do they use the done radio? $\endgroup$ – mins May 6 '16 at 22:00
1$\begingroup$ My guess is they don't. They're usually used over foreign soil where the whole idea is that nobody knows they're there. If they're flying around the home country for training or something they probably stay within an active MOA. I don't think they're flying them around cross-country. Although it would be interesting to see one landing at LAX. $\endgroup$ – TomMcW May 7 '16 at 0:10
$\begingroup$ Related $\endgroup$ – Pondlife May 7 '16 at 12:45
$\begingroup$ "On 18 September 2014, the Triton successfully conducted an 11-hour cross-country flight from Northrop Grumman's Palmdale, California facility to Naval Air Station Patuxent River in Maryland. ... The aircraft flew a pre-approved instrument route along the southern U.S. border" - en.wikipedia.org/wiki/… $\endgroup$ – nobody May 7 '16 at 22:06
Show 1 more comments
They have an onboard VHF radio that can be used to receive and transmit on local frequencies.
For example, on the MQ-1B Predator you will see a small fin on the back of the aircraft behind the GPS dome. That is an omni-directional antenna which can transmit VHF. The Global Hawk has a similar capability.
