Raymer tells (Source: Raymer: Aircraft Design – A Conceptual Approach Chapter "5 THRUST-TO-WEIGHT RATIO AND WING LOADING" Paragraph “5.3 WING LOADING” Subparagraph “Climb and Glide”) that, when the aircraft is climbing, if the climb angle γ is small,
then $G=\frac{T-D}{W}$
(G is Climb Gradient as defined by Raymer words: "Rate of climb is vertical velocity,.. Climb gradient G is the ratio between vertical and horizontal distance traveled. This is approximately equal to the vertical climb rate divided by the aircraft velocity, or the sine of the climb angle γ." Source: Raymer: Aircraft Design – A Conceptual Approach Chapter "17 PERFORMANCE AND FLIGHT MECHANICS" Paragraph “17.3 STEADY CLIMBING AND DESCENDING FLIGHT” Subparagraph “Climb Equations of Motion”)
Then $\frac{D}{W}=\frac{T}{W}-G$ ( that is the first relation for D/W).
At the same time $D=q\cdot S\cdot c_{D0} + q\cdot S\cdot\frac{c_L^2}{π\cdot AR \cdot e}$
And substituting $c_L=\frac{W}{q\cdot S}$,
$$\frac{D}{W}=\frac{q\cdot S\cdot c_{D0}+q\cdot S\cdot\frac{c_L^2}{π\cdot AR\cdot e}}{W}=\frac{q\cdot c_{D0}}{\frac{W}{S}}+\frac{W}{S}\cdot\frac{1}{q\cdot π\cdot AR\cdot e}$$
(that is the second relation for $\frac{D}{W}$)
Equating the first and the second relation and solving for wing loading, we have:
$$\frac{W}{S}=\frac{\left(\frac{T}{W}-G\right)± \sqrt {\left(\frac{T}{W}-G\right)^2-\frac{4\cdot c_{D0}}{π\cdot AR\cdot e}}}{\frac{2}{q\cdot π\cdot AR\cdot e}}$$
MY FIRST QUESTION: In this equation are both, the bigger and the lower solution values for $\frac{W}{S}$ realistic for aircraft?
After, Raymer notes that the term within the square root symbol in the equation above cannot fall below zero, so the following must be true regardless of the wing loading:
$$\frac{T}{W}≥G+2\cdot\sqrt{\frac{c_{D0}}{π\cdot AR\cdot e}}$$
MY SECOND QUESTION: Raymer doesn’t consider that there are two solutions sourcing from the condition that the term within the square root symbol cannot fall below zero, the other one is: $$\frac{T}{W}≤G-2\cdot\sqrt{\frac{c_{D0}}{π\cdot AR\cdot e}}$$. Why shouldn’t be considered? Could the second solution represent something realistic?
I HAVE A SUPPLEMENTARY QUESTION: Relating to my questions above, I have to report two comments Raymer writes immediately after the last equation and inequality.: "This equation says that no matter how "clean" your design is, the T/W must be greater than the desired climb gradient! ....... Another implication of this equation is that a very "clean" aircraft that cruise at a high speed despite a very low T/W will probably climb poorly. A 200-mph airplane that flies on 20 hp can't be expected to climb as well as an airplane that requires 200 hp to reach 200 mph (unless the latter weighs ten times as much)" Could anyone explain me better the last sentences, in particular, in which case T/W is very low with high speed? If we have high speed doesn't T/W should be high too?
(X)
that appears when you hover the comment with the mouse). You may edit your question by using theedit
link between the question tags and your signature block. $\endgroup$ – mins May 5 '16 at 15:04
