This is a followup to my other question on this topic. Figured I'd just make it a whole separate question.
The plates below show STAR arrivals to KMEM. The points along the route are marked with two different symbols. When I look in the FAA guide it refers to the triangular symbols as non-reporting fixes and the star shaped symbols as non-reporting waypoints. What is the difference between the two? Why are they marked with different symbols?
DAWGG TWO ARRIVAL
HOBRK ONE ARRIVAL
Fixes/ATC Reporting Requirements Legend
    $\begingroup$ The triangle points can be determined from conventional navigation (radial/dme and/or radial/radial). The 4-point star waypoints are only defined as RNAV waypoints. $\endgroup$
    – Ralph J
    May 1, 2016 at 18:41
As described in the answer to the previous question, all of the points on the chart are both waypoints and fixes. The difference between the printed icons is how they are identified from the air.
The waypoints marked by hexagons, some with darkened edges and some printed inside a square, note where the waypoint is on top of a VOR. This includes Razorback, Walnut Ridge, Gilmore, and Memphis. The icons with bolded sides are a VOR collocated with TACAN; inscribed inside a square notes a VOR collocated with a DME station.
Triangles are waypoints determined by a radial and distance from a VOR station. The star icons are determined by an RNAV (area navigation) system, which does not require the aircraft to fly a particular VOR radial to determine its course. Note that the procedure you provided is not available for RNAV-capable aircraft, likely because there is an RNAV arrival procedure that is preferred by ATC.
To fly the procedure, starting from the left, a pilot would identify the Razorback (RZC) point by their CDI showing that they had flown over the beacon itself. The next waypoint is MARBI; that is determined by flying along the 098 degree radial to a distance of 34 NM from RZC. Similarly, IGLOO can be identified by flying the 098 degree radial another 85 NM for a total distance of 119 NM. The distinct icons tell pilots how to identify the waypoints using their onboard equipment, but they otherwise have the same meaning.
  • $\begingroup$ Thank you. You just cleared it all up for me. I realized I uploaded the wrong plate. This one doesn't have the star-shaped waypoints. I went to find the one I intended and now I see that the star shaped icons are only on the RNAV plates since they don't coincide with a radial from another VOR. So they can't be used without RNAV. +1 $\endgroup$
    – TomMcW
    May 1, 2016 at 17:34
According to the Pilot/Controller Glossary:
WAYPOINT− A predetermined geographical position used for route/instrument approach definition, progress reports, published VFR routes, visual reporting points or points for transitioning and/or circumnavigating controlled and/or special use airspace, that is defined relative to a VORTAC station or in terms of latitude/longitude coordinates.
and
FIX− A geographical position determined by visual reference to the surface, by reference to one or more radio NAVAIDs, by celestial plotting, or by another navigational device.
They are pretty much used interchangibly, but a fix is just a point in space, where as a waypoint is a fix where the pilot might actually do something, although this doesn't always hold (e.g., the MAP)
Sometimes one or the other may be built directly into the nomenclature, like
  • DME Fix
  • Final Apprach Fix (FAF)
  • Visual Descent Point (VDP)
  • Missed Approach Point (MAP)
Sometimes you have to be very careful using fix or waypoint:
  • Missed Approach Point (MAP) -- where the land/missed decision must be made. It uses point and not fix because it may be determined by DH, a timer, or a GPS fix, even on the same approach chart.
  • Missed Approach Fix (MAF) -- where the missed approach hold is
In this example for the ILS at KMEM, the MAP may be determined either by:
  • 466MSL DA with a working GS
  • 4:18 seconds @60KIAS from the FAF with GS INOP
