Some time ago, I came across a GIF of a Russian military airplane doing a Kulbit manoeuvre (Probably for showoff). How, in terms of control surface movement, does an airplane to the Kulbit?
Source: Reddit
Source: Reddit
The Kulbit maneuver is a variation on the Cobra maneuver (Pugachev's Cobra) with a higher pitch rate and continuous positive pitch rate throughout the maneuver. It requires two things:
An electronic flight system is helpful to make execution easier, but is not strictly required. Also helpful is an engine-intake-combination which does not stall the compressor if the outer flow is reversed briefly. As you can see, the control surfaces only play a minor role - they are only important initially to start the pitch-up motion. This is done by negative elevator and/or positive canard deflection.
