If i understand correctly this is the "back work ratio". I'd like to know how much % of the "gross" thrust is used by the turbine to drive the compressor in a typical turbofan.
    $\begingroup$ Since you say turbofan, do you mean just the compressor, or both compressor and fan? Because in turbofan, most power is used to drive the fan. $\endgroup$
    Apr 28, 2016 at 6:22
    $\begingroup$ Just the compressor, since the fan generates useful thrust. $\endgroup$
    – Southbob
    Apr 28, 2016 at 11:32
