What type of flaps, slats or other high-lift devices are used on this aircraft?
  • $\begingroup$ I won't post as an answer as I don't have references to hand - but essentially: No slats, and single slotted flaps. $\endgroup$
    – Jon Story
    Apr 27, 2016 at 12:47
The Dash8 - Q400 - Aeroplane General PDF (courtesy of smartcockpit.com) indicates on page 27 that there are inboard and outboard flaps.
Reading through the Dash8 - Q400 Flight Controls PDF (also from smartcockpit.com) indicates that:
Two single-slotted inboard and outboard fowler flaps are attached to the trailling edge of each wing (Figure 12.8-1).
page 43
There is no indication of slats or any other high-lift device.
