I know that they repair everything that concerns engines, but what is the actual day for them. Do they sit in the factories or work in airports?
  • $\begingroup$ @mins After years of training, this guy has the technique down $\endgroup$ – TomMcW Apr 24 '16 at 17:15
  • $\begingroup$ @mins Fortunately, as bad as that looks, that guy was not seriously injured. Apparently a strap caught on something before he reached the fan. $\endgroup$ – TomMcW Apr 26 '16 at 11:49
  • $\begingroup$ @TomMcW: Ah that's indeed completely different :) Lucky man! $\endgroup$ – mins Apr 26 '16 at 17:08
You ask a very broad question. Jet engine technicians can work in various capacities depending on the job they are hired to do.
In my experience, I worked on the flight-line directly on aircraft removing/installing, performing operational checks, troubleshooting and servicing engines and other systems.
Some technicians work on engines out of the aircraft and in a controlled environment like the factories where engines are made. Others work in repair shops tearing down and rebuilding existing engines.
