Seeing the image of a Lockhead LC-130 doing a jet assisted takeoff in snow mentioned in this answer, I wonder:
What is the procedure for a rejected takeoff when using JATO? Can the JATO rockets be turned off once ignited?
Sign up to join this communitySeeing the image of a Lockhead LC-130 doing a jet assisted takeoff in snow mentioned in this answer, I wonder:
JATO (more correctly: RATO) typically uses simple solid-fuel rockets for their ease of maintenance, simple construction, long-term storability, robustness, and reliability. However, a simple solid-fuel rocket has to burn out once ignited, there is no way to shut it down. Techniques for extinguishing and even throttling solid-fuel rockets do exist, but they were developed rather recently, have not yet been commercialized, and clash with the goal of simplicity.
Currently, the "usual" way to shut down a solid-fuel rocket is to rapidly decrease the pressure in the combustion chamber, aka an explosive Flight Termination System, aka blowing up the rocket – not something you want to happen with a rocket strapped to your wings (IOW directly below the fuel tanks). Alternatively, you could get rid of that extra thrust by jettisoning the rockets. Having a dozen or so flaming projectiles uncontrollably flying around the airplane is also not a good idea.
So, you either reject before igniting the rockets or you don't reject at all. V₁ is when you hit the button, which may be as low as 0 kt, depending on the specific application.
Once the rockets are ignited, it is basically too late to abort the takeoff, so the decision would have to be made before doing that. This is one reason why RATO is not used today as much as it used to be, the increased power of modern turboprop engines reduces the need for it in any case.
Specific to the LC-130.’
After ATO ignition but prior to flying speed, a reject is performed by retarding the throttles to the ground range. If you can reach a flying air speed - you typically are not using ATO - unless the terrain is such that warrants a shorter slide to protect the airplane from higher risk.
The bottles burn, based on pressure altitude and temperature, for approximately 15 seconds.
The term “Jet Assisted” comes from the use of a solid propellant motor that produces its thrust by use of a “jet” or stream of hot gases through a rocket nozzle (a more literal use) appropriate of the time they were designed (early 50’s).
