I have read that is to help the flow remains attached, but I do not understand the physical principle.
$\begingroup$ Probably related: aviation.stackexchange.com/questions/24414/… $\endgroup$– SteveMar 31, 2016 at 16:30
$\begingroup$ Might not apply, though, since this is about an airfoil and not an aircraft nose. $\endgroup$– SteveMar 31, 2016 at 16:31
When using an airfoil with a sharp leading edge in subsonic regime, you need to adapt the angle of attack so that the stagnation point occurs right on the sharp edge.
At every flight condition there should be an AoA which achieves this. Higher AoA, and the stagnation point is too low. To low AoA, and the stagnation point is too high. However flight conditions change frequently, so the required AoA changes dynamically as well. Since AoA also drives the lift and lift is the priority in a pilot's mind (he wants to keep flying after all), stagnation point will only occasionally match the leading edge.
During flight the AoA will often fail to match the stagnation point, let's say with too high AoA, separation would occur below the leading edge (on the "intrados"). This is the only good illustration I could find:
The stagnation point is at the tip of the only grey line that stops right on the black plate. Basically all incoming flow between these leading edge and stagnation point (unfortunately no line shows this on the picture) will follow this trajectory:
- Incoming at high speed onto the airfoil, below leading edge, going towards the stagnation point, but aims just slightly higher up.
- The stagnation point is the point of highest pressure, so the incoming flow slows down
- Comes a point where the slowdown is sufficient to actually reverse the flow which now shoots up along the surface towards the leading edge, now driven by the pressure from stagnation point
- Arriving at the leading edge from below the flow needs to do a U-turn around the leading edge to keep following the wing shape and flow towards the "extrados" and keep on with its life.
Therein lies the problem: when finally arriving at the leading edge, the air has non-zero speed (zero speed only occurs at stagnation point, of which there is only one), but must instantly reverse it. Physics says nope, and you get a large leading edge vortex to smooth the motion out. Unfortunately that is also called a flow separation bubble, which may became a stall.
This is:
- bad for performance (drag)
- bad for safety (stallable)
- bad for comfort (vibration from the eddies)
- bad for structure (vibration fatigue)
Why does it only happen in subsonic flight?
At supersonic speeds, information cannot travel back on the flow using the same pressure gradient trick, once the air is on the intrados/extrados, it stays there, and cannot back up the other way. So no 'adaptation' is possible, regardless of AoA.
Why use rounded leading edge to remedy this in subsonic?
With a rounded edge, the U-turn is not so sharp, it is actually manageable for the air. This means you'll not always have flow separation, so you're safe. The rounder, the easier larger the range of AoA stay "adapted". This animated gif shows really well how the stagnation point can move around the rounded tip thus avoiding separation:
Source: UNIVERSITY OF GENOA FACULTY OF ENGINEERING DEPARTMENT OF ENVIRONMENTAL ENGINEERING IRROTATIONAL PLANE FLOWS OF AN INVISCID FLUID
TL;DR It's possible to fly subsonic with sharp leading edge, but less safe and lower performance. The key is AoA adaptation.
$\begingroup$ Welcome to Aviation.SE! I edited your answer to embed the image (and provided the source info), instead of having to request that we click the link to see it. That's the preferred method around here (unless there are copyright issues involved). You can click the 'edit' button to see how I did it so you can do that on your next answer! $\endgroup$– FreeManApr 13, 2016 at 15:52
$\begingroup$ Oh very good. I knew I should've added the source. For embedded image I thought I needed more priviledges to do it... Looks neat, thanks! Also for the rest, I didn't have source but my own [supposed] knowledge but people here seem to add a lot of references. I should look out more... $\endgroup$– MrBrushyApr 13, 2016 at 16:34
$\begingroup$ References for information are always good, but there are lots and lots of unreferenced answers, don't worry about it. $\endgroup$– FreeManApr 13, 2016 at 16:57
The short answer is that a blunt leading edge tolerates a wider envelope of angle of attack than a sharp leading edge. Making it even simpler to understand it makes the airplane more forgiving to fly than a sharp leading edge.
I'm certain someone will give a more thorough explanation consistent with what I have said here. I just thought it would be useful to give a quick reply.
There is no requirement for a blunt leading edge. Some low speed subsonic airfoils, such as the Wainfan Facetmobile, have sharp leading edges. Airfoil design has a lot of tradeoffs, lift/drag, predictable stall characteristics, etc.
